AirForce® 27i
120V/240V plasma cutter. Clean cuts up to 3/8 in. steel
How to Make a Fire Pit
Optional:
Top Frame: 4 - 1.5" x 1.5" x .125" angle iron x 36" L (cut ends at 45 degrees)
Legs: 4 - 1.5" x 1.5" x .125" angle iron x 18" L
Side Vertical Supports: 4 - 1" x 1" x .060" tubing x 33.5" L
Side Bottom Supports: 9 - 1" x 2" x .060" tubing x 8.5" L
Bottom Leg Supports: 4 - 3" x 3" x 3/16" flat stock (optional if fire pit on soft surface)
Pit Sides: See drawing
