Spool Adapter Hub Kit, 8 in.
195216
About The Spool Adapter Hub Kit, 8 in.
Keep your Hobart Handler running smoothly with this 8" replacement hub kit. Built for a precise fit, it helps support consistent wire feed and easy spool changes, so you can get back to welding with less downtime. Simple to install and made for real shop use, this kit is a practical fix for keeping your machine ready when the job calls.
