1.125 in. Diameter Pointer Knob
207079
About The 1.125 in. Diameter Pointer Knob
Keep your welder easy to adjust with this replacement pointer knob for voltage control on Handler 125EZ, 125MIG, 140, and Auto Arc 130 wire welders. Built for a simple, accurate fit, it helps restore clear voltage settings so you can get back to work with confidence. A small part that makes a big difference when you need your machine ready to perform.
