Oxy/Acetylene Twin Hose R Grade 1/4 in x 50 ft
770133
About The Oxy/Acetylene Twin Hose R Grade 1/4 in x 50 ft
Hobart’s 50 ft acetylene twin welding hose is built for smooth, reliable gas delivery. Complete with B fittings, it connects easily to your regulator and torch. The neoprene cover adds flexibility and helps resist kinks, so you can move with confidence around the job. Grade R, acetylene only, with 1/4 in. inside diameter and ready for steady performance when the work calls for it.
