Handler® 125 MIG Welder
120V MIG welder. Easy setup. Welds 25 ga to 3/16 in. Four voltages, thermal protection.
How to Weld a Decorative Snowman
Follow step-by-step instructions on how to weld a decorative snowman using the Handler® 125 MIG Welder.
240V plasma cutter. Clean cuts up to 5/8 in. steel.
Turn rebar pieces into a welded snowflake for your holiday display. Watch Braden Cowell, welding engineer at Hobart, arrange the pieces, weld the connections with the Handler® 210i and grind the finished snowflake.
