Replacement Pointer Knob. 1.125 in
211338
About The Replacement Pointer Knob. 1.125 in
Keep your wire feed control clear and easy to adjust with this replacement pointer knob. Built for the Handler 125, 140, 187, 190, 210, 210MVP, and Auto Arc 130 wire welders, it helps restore simple, accurate control when your original knob is worn or missing. A small part that makes setup straightforward, so you can get back to welding with confidence.
