Results 1 to 4 of 4
Thread: G213 Help
    Sep 2017
    2
    G213 Help
    Just picked up an old G213 with a Wisconsin TJD engine. The engine was full of water and I need to tear it down.
    Does anyone know how to separate the engine from the generator?
    There are two holes in the housing between the engine & generator to access the set screws on the shaft but even with the screws removed, I cannot get it to budge.
    Calgary
    1,886
    Quote Originally Posted by seabee54 View Post
    Oldfart used to send out manuals for these, but hasn't posted lately. Try a search for G213,and you will get some threads. Also, post all info on your spec plate and Hobart experts might have some info.
    Sep 2017
    2
    Thanks,
    I got a manual from Hobart but it had no info on this.
    If memory serves, this used a flex coupling with hub and keyway. There will two bolts that need to be loosened on the coupling. This is probably going to take a good puller to get these separated.
    Keith
