Results 1 to 11 of 11
    Nov 2004
    marin co. ca.
    2,201
    Cutting 52/50 1/8" Allum plate on woodworking band saw
    I cut out and make Allum diamond plate metal Bow Ties,
    I just ordered M-42 1/4"X0.025X 14 R blades from Bandsawbladewharehouse . The tightist Radius is 3/4" I use wax lube on blades.
    Any input appreciated Tool
    Feb 2006
    56
    It sounds as though you should be fine. As long as you keep the blade lubricated I see no problem.
    Nov 2004
    marin co. ca.
    2,201
    Quote Originally Posted by theweldor View Post
    Thanks Brother
    Jul 2012
    1,393
    Dont crowd it... I have been know to cut 1/8 sheet aluminum on table saw with carbide tipped (wood) blades... Kind of scary...
    Lives his life vicariously through his own self.
    Nov 2004
    marin co. ca.
    2,201
    Quote Originally Posted by Dale M. View Post
    Can't cut 3/4" radius on a table saw. So far I have made over 300 Bow Ties . Yes , straight cuts go to My table saw.
    Nov 2004
    marin co. ca.
    2,201
    Band saw blades like no other
    Just received My 1st order from bandsawbladewharehouse.com . All their bandsaw blades are made in Germany I have made over 300 Alum. Metal Bow ties. I have a cabinet making and welding shop. for the ties I use 52/50
    1/8" diamond plate Allum. plate . and I use My 14" delta band saw with a 6" riser. I couldn't find a weld joint on the blade. Better weld tech. than anything I've used before ! The cutting is effortless . All My metal and wood blades will now come from Bandsawbladewharehouse. Will post Pix of My Bowties later this week. Tanks Tool
    Sep 2003
    Clark County, NV
    5,201
    Pretty sure you mean https://www.bandsawbladewarehouse.com/
    Only that one "h" in warehouse. I only mention it to make it a working link.
    Carbide-tipped bandsaw blades, too. Wow:
    Nov 2004
    marin co. ca.
    2,201
    Thumbs up Thanks for watchin Me back Brother
    Quote Originally Posted by toolaholic View Post
    Im an OLD FART !
    Dec 2015
    SouthEastern VA
    13
    Where are the pics?
    I really want to see a picture of your bowties.
    Nov 2004
    marin co. ca.
    2,201
    WELL I'll have to ask the Bride
    Quote Originally Posted by shady View Post
    How to post Pictures in a day or 2
    Dec 2015
    SouthEastern VA
    13
