Old 10-02-2009, 08:21 PM
kurtk87 kurtk87 is offline
Junior Member
Question Hobart handler 210/ millermatic 211
Hi everyone I am looking to upgrade my old lincoln pro mig 135 to either the Hobart handler 210 or the millermatic 211. I am an experienced welder that knows how to set up the proper voltage and wire speed so my question is, is there really any advantage to the millers auto set fuction or not. Also i would like anybody elses opinion on these two welders. Thanks
Old 10-02-2009, 10:36 PM
Tom37's Avatar
Tom37 Tom37 is offline
Kurt, I have the 211AS. I have never used the 210 so I cant really say the 211 is better or not. The other day I was working on a little project that had thickness difference from 10 ga to 3/8. None of these were critical welds, well I guess they are all critical but these wouldn't hurt anyone if they failed. I set the autoset dial to .035 and tried out the A.S. feature. To me it didn't seem to be a perfect set, there was a little more splatter then I like but it was very close. It was really nice to jump around on the project from thick to thin with only changing the thickness setting. I am sure if I welded every day for a living, that I would just change the settings the old way and not even think about it. BUT I forget easy and usually double check the door, so the A.S. was pretty slick since I was jumping all over on thickness.
Stickmate LX 235 AC / 160 DC.
MM211 AS and Spool-Mate 100.
Clarke 180 EN. Just incase
Spectrum 375 X-Treme.
O/A Medium Radnor Torch, Large Victor Torch.
Milwaukee 14" Chop Saw.
4 x 6 Horizontal Band Saw.
Rockworth 80 Gallon 2 Stage 16 SCFM @ 175 PSI , 15 SCFM @ 90 PSI.
Jackson Passive Shade #5 for the plasma.
I almost forgot the Hobart XVP AD Hood.
Projects and Misc Albums
http://picasaweb.google.com/keesfriend Feel Free to Have a Look ( Just keep in mind I am an amateur )
Old 10-03-2009, 12:20 AM
Junior Member
Thanks for the help, I do weld everyday at my job so changin the dials isnt a big deal to me, and since you said the (AS) setting wasnt spot on anyway i think im gonna go with the hobart it is a little more budget friendly. Thanks for the input.
Old 10-03-2009, 12:29 AM
dda52's Avatar
dda52 dda52 is offline
That's what I would think..the AS wouldn't let me do what I was wanting to do. That would make me mad, too. I was using the H210 today and am still impressed how well this little dood welds.
I'd say...If you know what you want to do weld-wise, then get the unit that will let you do what you want, instead of what some engineer thinks you should do.
Don
Go Spurs Go!!!!!!
Old 10-04-2009, 09:44 AM
FWI's Avatar
FWI FWI is offline
I would buy the HH 210 for the money. For the extra $$$ you get 10% higher duty cycle at 150amps, Autoset and Blue Paint. Don't get me wrong I'm a Miller man for heavy fabrication but for your personal needs I'm a Hobart Man or guys are having great luck out of ESAB. Just my $.02
Beware of the man with one gun.
Old 10-07-2009, 10:06 PM
SavageSunJeep's Avatar
SavageSunJeep SavageSunJeep is offline
Member
I run the MM211 AS and did not think I would like it...but I love it! And I love it along with the 211 for several reasons:
1) The Auto Set feature is strictly optional, you do not need to run it. You can set your wire speed etc just like any other welder so if you don't like it then skip it...but do try it.
2) The AS feature is variable. Its not a 'click-stop' at different metal thickness. So if you can still adjust the setting and the neat part is the metal thickness which is variable drives the wire speed which is also variable. I have found that by simply adjusting your metal thickness setting +/- I get excellent results, less splatter and far superior welds. I adjust based upon penetration and how the weld is forming, telling me whether or not I need +/- adjustment. It really lets me fine tune my welding process.
I honestly did not think it was such a good thing when I read about it, but in use its really a leap forward IMO.
Don
Scottsdale, AZ
www.SavageSun4x4.com
MillerMatic 211 AS
Hypertherm PowerMax30
Bernard 300 Amp Q Gun
Milwaukee Bandsaw/stand
8 Angle Grinders
DeWalt Chop Saw
Craftsman Twin-Blade Saw
12 Ton Shop Press
Optrel Satellite Helmet
Miller Elite Helmet
  #7
Old 10-08-2009, 08:49 AM
fjk fjk is offline
i'll sort of second savageSunJeep's second point --
I'm not an expert, by any means. I have a MM140+AS. I find that
whenever I use it I get close, but it's always off a bit, so I end up
diddling the knobs a bit. Following the chart on the machine
gets me just as close - maybe closer - than AS does. Either way
I end up diddling knobs and adjusting the torch angle/distance/etc
so in balance, AS isn't that big a win for me. On the other hand,
the price difference was something like $40 -- which in the grand
scheme of things, just isn't that big a deal...
Look at the machines for their basic capabilities first, and think
of AS as a tie-breaker, should it be needed.
YMMV
Frank
  #8
Old 10-08-2009, 11:26 AM
Member
You are right about 'diddling'...That said I find that I now only have one knob to diddle rather than two I did in the past.
I guess I just see it as simpler diddling and less time bending over and opening the door to read the chart.
As for accuracy, I find the chart to be more or less and the AS to be on the 'hot' side and I most often need to run on the low side of the metal thickness...
Don
Scottsdale, AZ
MillerMatic 211 AS
8 Angle Grinders
DeWalt Chop Saw
12 Ton Shop Press
Miller Elite Helmet
  #9
Old 10-08-2009, 12:55 PM
Broccoli1's Avatar
Broccoli1 Broccoli1 is offline
AS feature means nothing to me but
MM211 does offer dual voltage 120v/240v
Cyberweld$ 970.00
but but...
HH210 WITH Spoolgun @ Northern Tool 899.00
probably rather have the Spool gun myself-
Lincoln SP 135+, SO 2020 Bender
  #10
Old 10-08-2009, 02:04 PM
Scott V's Avatar
Scott V Scott V is offline
I think I would look at the cost and complexity of the circuit boards. Bet the 210 would be worth fixing after the warranty is up. Probably just have to crush the other one.
