Old 11-23-2006, 10:37 AM
vicegrip's Avatar
vicegrip vicegrip is offline
Tap Modification___No brakee if you hit........
the bottum of a blind hole , or a hard spot .........
there is not much radial load on the first 2 or 3 teeth ....... so by weakening the flutes from behind and carving out the center .........the first teeth to hit the bottom (CNC operation) or a hard spot .....will snap off giving audible warning and leaving the body of the tap intact....
also remove the 60 degree point from taps groung with a male center .....as it will self destruct the very milla-second the point hits the bottom of a hole (CNC operation)
the point though makes a better center-punch than any center punch does .....or a rigid scriber for scribing cutter paths.....save the dull ones from thru hole tapping
Old 11-23-2006, 12:04 PM
tailshaft56 tailshaft56 is offline
No fair showing Steak and Shake cups on a Holiday when they are closed. Other than that you have some great ideas there Vice.
Dennis
Thermal Arc 185-TSW
Millermatic Challenger 172
VictorO/A
Esab PCM-875
Wholesale Tool Mill-Drill
Old 11-23-2006, 01:24 PM
vicegrip's Avatar
Quote:
Yeah ! My son had to see an anillist when the one here closed up
He's about one bowling ball lighter now
