Old 03-23-2006, 06:57 PM
Arc Stryker Arc Stryker is offline
Junior Member
New Grizzly Band Saw
Well after looking for the last few months and trying to see all the saws, I finally ordered the Grizzly Band Saw. Seems like the people I talked too who had one really were satisfied with their Grizzly. so I just thought I'd bite the bullet and try it.
when I get it, what blade do you guys recommend ordering to have on hand? (TPI & bi-metal) and where's the best place to get it.
Hobart Champion 10,000
Hobart Handler 140
Hobart Air Force 400 Plasma Cutter
Victor OA torch
6 HP 60 gallon Craftsman Compressor
Grizzly 4 x 6 band saw
Old 03-23-2006, 07:21 PM
Grappletractor's Avatar
Grappletractor Grappletractor is offline
How does it compare to the Jet ? Price ?
Old 03-23-2006, 07:46 PM
Junior Member
The Grizzly is $50 more than the Jet, I'm anxious to get it and see how everything looks.
Hobart Handler 140
Victor OA torch
Old 03-23-2006, 08:19 PM
I have my eye on the Jet for 269
Old 03-30-2006, 08:13 PM
Junior Member
Well I finally got time to put together my saw and play with it a little, still gotta put on the belt guard, but it seems like it cuts fine, anybody got any unposted tips for making the most of my saw.
Hobart Handler 140
Victor OA torch
Old 03-30-2006, 08:56 PM
Hotfoot's Avatar
Hotfoot Hotfoot is offline
I used the Grizzly Bi Mteal blades on my HF. They were pretty good, but Morse blades from Enco are the same price, so I but them now.
  #7
Old 03-30-2006, 09:12 PM
pgpettigrew pgpettigrew is offline
Junior Member
oops!! Here is a tip for you.
Quote:
I had an unfortunate mishap while moving my father-in-law's HF 4x6. I lifted the saw up on its wheels to roll it and the head was unsecured, it flipped up and the saw tipped over busting the belt guard into several pieces. Make sure the head is secure or move the wheel to the opposite end of the motor before picking it up to high.
  #8
Old 03-30-2006, 09:15 PM
Junior Member
P.s.
Parts from H.F. still atleaste a week out.
  #9
Old 03-30-2006, 09:42 PM
Broccoli1's Avatar
Broccoli1 Broccoli1 is offline
Quote:
Enco and Morse blade here also
Lincoln SP 135+, SO 2020 Bender
  #10
Old 03-30-2006, 09:50 PM
chabat's Avatar
chabat chabat is offline
I just bought the HF 4x6 bandsaw. Now I am blade shopping too. I found the Enco website. I will be cutting mild steel exclusively. What would be better the Morse 10tpi or 14tpi or 10-14tpi bi-metal blade?
You hammer the iron that lay on your anvil, instead of daydreaming of working silver.
  #11
Old 03-30-2006, 10:12 PM
Hotfoot's Avatar
Quote:
The number of teeth relate to the thickness of the material. More teeth per inch =thinner material. I use the 14 for everthing, and it does fine....most of my cuts are thick stuff ( 1/4" + up.
  #12
Old 03-30-2006, 10:21 PM
chabat's Avatar
My range will be 14 gauge to 1/4 mild steel, and some occaisional thicker round stock like up to 5/8". So 14tpi sounds like it would be better for me. 1/8" thick will be the most often used thickness.
  #13
Old 03-30-2006, 10:58 PM
fallon416 fallon416 is offline
Member
A good general purpose blade for the hobbiest that cuts mild steel and aluminum is a 10 - 14 tpi bi-metal blade. I buy mine from Enco. Your saw probably comes with a 14 tpi blade as most of the 4x6 saws due.
Neil
The more I learn the less I remember.
  #14
Old 03-31-2006, 08:14 AM
toolaholic toolaholic is offline
morse lasts
morse morse morse or morse
  #15
Old 03-31-2006, 08:50 AM
IRON TO ART's Avatar
IRON TO ART IRON TO ART is offline
Starrett blades bi-metal only for me 14TPI. Of course I get them from the company I work for at cost.
Doug Arthurs
Kent Bridge Ontario
