Old 01-26-2006, 08:34 PM
opc1 opc1 is offline
Junior Member
.065 ew tubing, strong enough for a kart frame?
I am in the planning stage of building my self, I mean my kids the go kart I always wanted as a kid. I intend to use 1" round tube, is .065 wall ew tube strong enough or do I need to use DOM tube or go to a thicker wall ew tube or dom tube with a thicker wall? If .065 is not enough what is the recomended wall thickness? I want the kart strong, but I do not want it to weigh a 1,000# either. I normally use steel that is probally 1/2 agian thicker than it needs to be, this is the first project that weight will be important.
Jeff
Old 01-26-2006, 09:23 PM
Vipernut's Avatar
Vipernut Vipernut is offline
I would use a .100" wall tubing for that. Don't waste the money on DOM. .065 is a little too small especially for places where the suspension will be tied in.
Kevin
Fire! Fire! - oh, wait... that's my torch.
Lincoln PT-225 TIG
Lincoln 175 MIG
Old 01-26-2006, 09:24 PM
PoisonPancakes's Avatar
PoisonPancakes PoisonPancakes is offline
Member
Me and my brother build one out of .095 wall and we never had any problems with it, even with both of us on it (about 350 lbs).
Hobart 135
Old 01-26-2006, 10:51 PM
Sandy Sandy is offline
I just did some work on a used one purchased for my grand daughter. It was mostly 1 inch .080 wall with smaller sections here and there. It was 'okay' as far as a kiddy cart. If I were to do one I'd make it a bit heavier tho. Get it much heavier and you'd have to go up another horse or so or beefier clutch system.
Old 01-27-2006, 09:16 AM
dsergison's Avatar
dsergison dsergison is offline
upsize to .090
I bought a bunch of .065 stainless because it was on great sale..... I have found it to be a bit to light for most things.
unless youre plan was to scientifically gusset and x brace everything... i think you'll find the .065 too springy for a basic flat platform go-cart frame
T/A 185
Old 02-01-2006, 06:26 PM
Junior Member
Thanks for the info everyone. It turns out I will not have to build the frame, I was on my way home from work Tuesday and found a Yerf Dog cart that needa a converter and picked it up for $150. The kids can help me fix this one, they will have to learn there welding skills on another project.
Thanks agian,
Jeff
  #7
Old 02-01-2006, 09:00 PM
fastblast fastblast is offline
Member
i was goin to say why not look into some chromoly. i'm goin to build an atv frame out of it for drag racing.
  #8
Old 02-22-2006, 05:48 PM
blkbk blkbk is offline
Junior Member
.100 x 1"
The .100 x 1" tubing should work fine for your project, the .65 is too small. It would bend too easily in the case of a crash. Unless you are going to put in a big engine, over 15hp, there should be no need to use anything more expensive or bigger tubing. if you are going to ride in it periodically, use 1 1/4 tubing AND gusset the corners real good and put in lots of bracing.
