Go Back   Weld Talk Message Boards > WELD TALK TOPIC ARCHIVE > Welding Projects
Thread Tools Rate Thread Display Modes
Old 11-09-2005, 05:03 PM
tonyclifton tonyclifton is offline
Need ideas for a base for christmas tree silhouette
A garden shop wants me to make some steel christmas tree silhouettes so they can string lights on them for decoration (maybe candy canes too). We're talking maybe 6 feet tall, 4 to 5 feet at the widest and only a few inches thick as I'll be using 1"x1/8" bar stock. I can make the tree fine. I just can't think of a cheap, quick to build base that will balance this tree.
A simple square frame (maybe 3'x'3) of the same bar stock would have too much flex IMHO plus my scrap supply is usually warped a bit so I can't always form level squares. I also thought of a simple 3x3 rebar frame (1/2") but just not sold on the idea. The owner thought I could just use some plate but he doesn't understand what that costs. I'm going to try and make these trees in no more than 1/2 hour each and maybe get $50 apiece so I need something cheap, quick and effective for supporting these trees. I will probably want to weld a piece of square tubing in the middle as a post to accept a smaller piece welded to the tree.
What will make a suitable base??? I been scratching my head all day.
Old 11-09-2005, 08:46 PM
James D. Clark James D. Clark is offline
Make a three legged base out of re-bar loaded with flat sand bags to anchor the trees.
Jim-bee
Old 11-09-2005, 09:09 PM
the hat the hat is offline
Member
How about 2" exhaust tubing instead of the square and use a standard Xmas tree stand
Old 11-10-2005, 12:58 PM
I'm concerned a christmas tree stand would be too tippy, as well as add to the cost of this cost-sensitive item.
Old 11-10-2005, 07:59 PM
Hotfoot's Avatar
Hotfoot Hotfoot is offline
Those plastic weight lifiting weights are found used dirt cheap. Look at the Goodwill store or in the local nickle shopper. they'd be great, stack a couple if you wis, have a simplenut welded onto a washer for your bottom, straw for "liner", concrete or Bondo to fill hole.
Old 11-11-2005, 02:28 AM
Winger Ed.'s Avatar
Winger Ed. Winger Ed. is offline
It ain't exactly a tree, but it does capture the spirit of the season around here,,,,,,,,,,,
I humbly submit, 'redneck christmas lights' for your consideration......
Circa 1900.
  #7
Old 11-11-2005, 02:33 AM
Mike W's Avatar
Mike W Mike W is offline
LOL Winger. An old wheel filled with concrete makes a good base. That is what I use on my grinder.
  #8
Old 11-11-2005, 08:21 AM
Hilarious Winger!
I realized I don't haver to have a central base. I might make a leg that pivots back and supports the structure from behind. It could attach to the silhouette with a bolt and wingnut and then have a pad on the end of the leg(s) that a simple rebar stake could go thru to lock it down to the ground. Simpler at least to build. Should be plenty stable.
  #9
Old 11-12-2005, 12:57 AM
Winger Ed.'s Avatar
Quote:
Originally Posted by Mike W
LOL Winger. .
Is that a hoot or what.... I think the same guy has a old comode with flowers growing out of it in his front yard too.
Circa 1900.
