Lift arc has its purpose, but it is way down on my choice of starting a tig arc ( because most of my tig work is bench work in the shop).
I made the mistake of getting a dc only tig , had to buy another machine down the rode, because welding aluminum is so **** cool , but the best aluminum welds need an AC/DC tig machine
You know reading through this thread again some other opinions of mine have come up and of which I think I'll spew forth...
1) pulse tig for steel welding, nope don't even use it for aluminum
2) adusting the range of 'balance', yepper there are some uses for that whistle.
3) # 2 means the T/A 185 , has the advantage over the Precision tig mentioned.
4) If your choice of machine can use a remote (ie plug for foot pedal or thumb switch) its a good thing, some dont use or need it, but it works for me.
5) always buy as much amps as you can afford
6) DC only machines have their places, namely used as less expensive maintence welders, not ideal for an all around shop fabricating tool, but you can buy more DC only amps than ac/dc amps for the same $ something to ponder.
Summary: 1) tig with lots of amp output 2) foot pedal or other to control current on the fly (besides technique). 3) AC/DC of = power to DC only machine can do more.
