I bought one of the less expensive AD hoods off of eBay and also one from Harbor Freight. Both work well for stick welding, but both will absolutely blind me when using my MIG. I'd mentioned this in another thread as well. With the cheaper AD hoods, I had to "blink" when the MIG arc started or I'd be blinded. With my stick welder, it always throws off a few sparks before the arc and the cheaper AD hoods are just fine. I tried every adjustment on them (both go from 9 to 13), but I was still blinded when starting a MIG.
Based upon the fact that I don't want to go blind, I went ahead and bought a more expensive Miller Elite Big Window (or whatever they call it). Talk about a difference!!
There are adjustments for the sensitivity and other things besides just the 9 to 13 darkening adjustment. I no longer have to "blink" to prevent being blinded when starting the MIG. Oh, I even borrowed a neighbor's cheap AD helmet and it too blinded me when starting my MIG arc. The Miller hood does not.
If you don't mind the required "blink", then the cheaper hoods seem to work fine. Myself, I don't like to have any tricks to using my equipment. I basically wasted 50 something dollars twice trying to avoid spending a couple hundred dollars to start with on a good AD hood. From experience, I'd say that if you stick weld, go with the cheaper AD hoods; they are fine for that. If you MIG, I'm telling you, the cheaper hoods just flat do not react as quickly as the more expensive hoods. I guess you do actually get something for that extra money spent. To me, my eyesight is worth more than $100 or $150.
