Hobart
Weld Talk Online Forum
Trek 180
Champion Elite
AirForce 500i
AirForce 700i
Spoolgun
Ironman 230
Premium Weld/Multi-Use Unlined Gloves
EZ-TIG 165i
XVS Patriot II
Go Back   Weld Talk Message Boards > EQUIPMENT TALK > Stick Welders
Reply
Thread Tools Rate Thread Display Modes
  #1
Old 07-22-2010, 08:52 PM
justin1976 justin1976 is offline
Junior Member
Hobart Stickmate 205 AC to Portable Generator
I have a Hobart Stickmate 205 AC welder as seen here and I also have a Troy-Bilt 6200 Running Watts Portable Generator as seen here. I'm wondering if it is possible to run my welder with my generator? I can't connect the welder to the generator currently because the generator doesn't have the required 220 receptacle however it does have a "120 240v 4 prong" receptacle as seen in the link above. Is that generator receptacle capable of running my welder with some kind of special adapter or am I out of luck?
  #2
Old 07-23-2010, 08:44 AM
Sberry's Avatar
Sberry Sberry is offline
Senior Member
You can plug it in with adapter but I am not sure it would run it if you did. These type machines are fairly greedy with electric demands, they are cheap to buy but not efficient, not a big deal plugged in to the wall but problematic with limited gensets. I think it would take about 8000 watts to power that machine decently. Says it has 9 K surge, maybe??? Spose you could try it.
You need a plug that fits the gen, a 3 conductor cord, ideally a number 10 and a recept, a 6-50-R that fits the welder.
__________________
www.urkafarms.com
  #3
Old 07-23-2010, 09:19 AM
SidecarFlip SidecarFlip is offline
Senior Member
I don't believe the genset will pull the load on arc strike. I believe it will trip the genset breaker.
__________________
So little time...So many machine tools.........
www.flipmeisters.com
  #4
Old 07-28-2010, 11:59 AM
Blacksmith Blacksmith is offline
Senior Member
The numbers appear to work, but the little gensets don't have the reserve/surge capacity to support striking an arc.
__________________
Blacksmith
Stickmate LX AC/DC
  #5
Old 07-29-2010, 07:16 PM
RickCHowe RickCHowe is offline
Junior Member
Welder plugged into a generator
Hi
I have a Lincoln AC-225 and I had it plugged into a Generac 4000 watt generator. Here is what I got. I could weld 3/32 rod 6011 and 6013 barely with the setting at 140 amps and that was it. I couldn't get it to work over 140 amps on the welder dial. And it wasn't really 140 amps. It stuck a lot. I did not have the full range of the welder. Although I did some welding with it, there is no comparison to welding with a gas engine arc welder. The gas engine arc welder by far is better at welding. I bought an old Lincoln weldon 130 which is a gasoline welder and generator. I am selling the Lincoln buzz box and the Generac generator. I could have saved some money if I did this in the first place. Just my 2 cents.
D I C K
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Please read our Terms of Use. Messages that harass, abuse or threaten other members; have obscene or otherwise objectionable content; have spam, commercial or advertising content or links may be removed and may result in the loss of your posting privileges. Please do not post any private information unless you want it to be available publicly.
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
