Results 1 to 10 of 10
Thread: Silver solder
    Jun 2004
    Sadorus Il
    976
    Silver solder
    Anyone know of a good online source to get silver solder in the bigger rolls?
    HH180
    Cutmaster 51
    Central Kali
    5,292
    How big a roll do you want? A little goes a long way.
    Jun 2004
    Sadorus Il
    976
    Not sure of the weight but the rolls are about 5 in in diameter.and about 2 inches thick. I found what i was looking for on the harris site but there are no prices listed,
    HH180
    Cutmaster 51
    Central Kali
    5,292
    Does $10 per pound sound about right? Of course it depends on the silver content. Or is that $10 per oz?
    maple ridge, BC
    92
    forget the rolls buy it in rod form with the flux already on it...way better. its $$$$$ but high silver content is what u want anyway.
    AmaC
    MM175
    O/A torches
    snap on everything
    Nov 2004
    NJ
    16
    are you looking for solder with silver content or brazing rod ? 2 totally different animals
    Jun 2004
    Sadorus Il
    976
    solder that comes in rolls. used primarily to repair aluminum radiators in the newer cars.
    rods would be fine but wont fit on the rig i have set up to put rolls on and pull out and use what i need and just let it hang.The desination is AWS A5.8 B Ag 5 (i think the last number is 5)theres a # 45 on the roll also.
    HH180
    Cutmaster 51
    Nov 2004
    NJ
    16
    to solder aluminum you should use "alsolder 500" w/ stay clean aluminum flux and to braze it you should use "al-braze 1070" w/ albraze aluminum powder flux if your going with jw harris. They are the best for alum to alum joints.
    Jun 2004
    Sadorus Il
    976
    The stuff i have now works great,just trying to find it cheaper.
    HH180
    Cutmaster 51
    MM (alis "70")
    Response on other board...
