Results 1 to 4 of 4
    Jul 2004
    Shreveport LA
    231
    Off The Subjectt
    When I moved from Phoenix to here in Louisiana I brought with me a "new" 4 ton Trane heat pump/ac from the house I was building in Phoenix.
    Next week I am installing it in my welding/auto shop here , 800 sq feet.
    I know, overkill again, but why not use it. Paid $4000.00 for the unit in Phoenix and the ac guy here will do basic install for $600.00.Through the wall with duct type install.
    Any Thoughts??
    John
    Nov 2004
    Detroit
    543
    well, I know with residential AC installations, the sizing of the outside condensor is based on sq. ft in the house.
    In that application going too big is a no-no.
    This might be a totally different set of rules for your big trane, and in a larger shop environment (with possibly much taller ceilings as well) though, I don't have enough knowlege to advise.
    I know in Louisiana, you will more than likely see plenty of condensation, and hopefully no freezing.
    Good Luck!!!
    Nov 2004
    marin co. ca.
    2,075
    answer john
    go to hvactalk.com greattttt site all hvac guys
    Jul 2004
    Shreveport LA
    231
    Thanks, that is a great forum!!
