I bought the Spoolmatic 30A to run with my 251MM. I still haven't hooked it up yet, but bought some 100% argon gas and aluminum wire (1# spool). I also bought some hard wire (2# spool) for a project in a tight area where my standard MIG gun will not reach. It's guite a bit of welding so I'd rather run MIG than stick. The manual states that you can run hard or flux core wire through the spoolgun, but does not say anything about weight limitations of the spool. Is it alright to run this 2# spool? Will the heavier 2# roll wear out the drive mechanism in the spoolgun faster than the 1# spool?
..It is just the nature of the steel being heavier than aluminum that makes it come on a 2# spool versus 1# for the aluminum. I have customers who have run literally tons of steel, on 2# spools through 30A's and other spool guns without a problem.
Now I just have to buy a TIG machine and find all the reasons/uses for it also
