Results 1 to 6 of 6
    Jan 2003
    Toledo Ohio!!
    91
    Talking Hobart Beta Mig 251
    Another Ebay score, was looking for a 175 miller but couldnt pass this up so bid on it and won the auction $500.00, cheaper then a 175 miller and has more power to boot The lady said that it had a new 15 foot Abicor Alpha Series Air-cooled Mig Gun and 1/2 a 33# spool of 0.30 left.
    Anybody know the duty cycle on this machine? I am still waiting for it to come in @ the local forward air so I can't run out and look and also the weight ( I gotta unload it out of a lifted 4x4 )
    ~Nate~
    NCLS LLC.~ Big Nate's Plowing
    ~~~~~~ I like a nice piece of SCRAP~~~~~~
    NCLS LLC- SMR Division (Scrap Metal Recycling)
    I FOUND A CHEAP TIG :~D
    Troy, Oh
    214
    Look at the Hobart Iron Man 250 it is very close to this design. I would say it has a 60% duty cycle and it will weld up to 1/2 in a single pass. As for the weight I would be around 180 LBS. It is a 230 volt single pase unit and has about a 40 amp input rating.
    Dave Evans
    Houston, Texas
    3,702
    Beta Mig
    You should be able to order a owner's manual for it from Hobart.
    Hobart Expert Rock Guest
    BIG NATE...........DUTY CYCLE IS 60% AT 200 AMPS, 100% AT 160 AMPS...NET WEIGHT IS 225 LBS....GROSS IS 245 LBS.....GET HELP TO LIFT IT OUT UNLESS YOUR REALL BIG ...MANUAL IS STILL DOWNLOADABLE ON THIS SITE..... WON'T DOWN LOAD LET ME KNOW AND I GIVE YOU ELLEN'S NUMBER AT MILLER SHE CAN GET YOU ONE FOR $15.00 USA FUNDS................HEY ENJOY I AT ONE TIME OWNED A EARLIER VERSION OF THE MACHINE......................YOUR ABOUT TO HAVE SOME FUN NOW...........PARTS ARE STILL AVAILABLE......GIVE SERIAL NUMBER AND I'LL GIVE YOU THE YEAR OF MFG......... LOOKS LIKE A GOOD DEAL TO ME...........I SOLD MINE FOR MORE THAN THAT......................SEE YA.................BE SAFE...........
    ROCK.............. SSCOTT@MILLERWELDS.COM
    Jan 2003
    Toledo Ohio!!
    91
    should be a improvement over the 110 machines
    BIG NATE........... WELL WILL WELD A LOT MORE IN SINGLE PASS THAN THE 110'S.............. .............BE SAFE NOW.......................ROCK....SSCOTT@MILLERWELDS.COM
