    Jul 2004
    Virginia
    416
    Rocky mentions flux core for his rebar projects...
    And since I like to weld rebar sculpture I was wondering why flux core over solid? 99% sure I'm getting a HH140 to sideline my lowly 110V 80A A/C welder and just assumed I would stick with solid with gas to achieve the cleaner (less spatter) results. Is flux core somehow better for welding up rebar?
    Jun 2004
    sw sub chicago
    424
    flux core gives a little better penetration
    97 s-10 vortech v2, fmic. a broken down 13.8 @ 97
    200dx
    sp135+
    port-a-torch
    miller big window
    other stuff
    Bulverde, tx.
    3,178
    MIG doesn't like a lot of junk, trash, scale, rust and or coatings. Rebar can have all of these. Fluxcore doesn't mind some rust or dirt as much as solid wire. At least it would keep you from having to clean so much before you weld.
    Don
    Go Spurs Go!!!!!!
    Jul 2004
    Virginia
    416
    Hmmm, well how does flux-core compare to arc welding with regard to amount of spatter? I do mostly weld junk, rebar, etc and was going to get the MIG (HH140) soon.
    Bulverde, tx.
    3,178
    Not much difference in flux core and stick. The beads will even look comparable.
    Don
    Go Spurs Go!!!!!!
