Results 1 to 7 of 7
    Nov 2003
    15
    lincoln square wave 175 problem
    i was tigging some sheet metal my five year old machine when it just shut down. checked the power for a blown fuse but that was ok. never happened before.. looked for a reset button on the machine and there isn't any visible one.... waited a half hour and tried to switch it back on..nothing...read through the troubleshooting guide... not much help there... my question is: has anybody had a similar experience with their sw175??
    999
    Well if your incomming power is "OK", first check your machine switch. It's likely that that has failed. Since you didn't mention if there was a puff of smoke, the primary transformer is probably OK.
    Nov 2003
    15
    went back out about an hour later and it worked just fine...!!..?? oh well..if it does it again i'll check that switch.. thanks
    AusTX
    195
    Sounds like some sort of internal overload/overheat protection that reset itself. Were you pushing up against the max amps limit or duty cycle limits?
    Aug 2004
    Manchester Wi.
    96
    Weakened or faulty thermocouple?
    Mac's Welding and Repair
    Go karts and mini choppers.
    Nov 2003
    15
    i was tigging some .040 sheetmetal, so i had the machine set for about 40 amps...nothing unusual...i'll be back out there today...see what happens...thanks
    Tennessee
    594
    I have the same machine (for sale, by the way). I do know that it has thermal overload protection, but it shouldn't have cut off at the amperage you were running. Maybe your breaker's not working well and causing a heat buildup... (just a guess).
