Results 1 to 7 of 7
    Jul 2004
    Midland Texas
    317
    Looking for a Spool Gun.
    Anyone have a used Spoolgun set up that will work on a MM251 for sale? I am thinking about playing around with aluminum a bit with my MM251. Or a good source for a reasonable price new one?
    Lincoln 200SA
    TrailBlazer 275
    MillerMatic 252
    Hypertherm Powermax 600
    Houston, Texas
    3,703
    Quote Originally Posted by GunLocators
    Go to Ebay and type in the model of the spool gun. IOC carries the 3035 for the MM210. I don't know which model you need but they probably carry it also.
    Just looked; the 15A:
    http://cgi.aol.ebay.com/ws/eBayISAPI...sPageName=WD1V
    Not cheap! BR has the same price. I didn't see a used one.
    Jun 2004
    sw sub chicago
    424
    get a new liner & proper tip. clean the machine real well. load some 4043 & set the feeder tension as low as possible. then practice and don't be discuraged, it takes practice.
    97 s-10 vortech v2, fmic. a broken down 13.8 @ 97
    200dx
    sp135+
    port-a-torch
    miller big window
    other stuff
    North Canton, Ohio
    69
    I also have a 251 and was in the market for the spoolgun . Last week I went to my local shop, and got the 30A spoolgun, regulator, 2 rolls of wire, a 10 pack of tips and a filled tank for $991. I opted to build my own rack for the tanks,since the factory unit was another $180. I'll try to post pics of the running gear later.
    Now if I can get them to get me a deal on a TIG. Thinking econotig, unless someone can talk me into something else.
    Jul 2004
    Midland Texas
    317
    Maybe TIG is they way i should go?
    Lincoln 200SA
    TrailBlazer 275
    MillerMatic 252
    Your 251 will MIG Al just fine. The Miller 15A (15' lead) and 30A (30' lead) spoolguns are "plug and play" on your machine.
    I'd never dicourage anyone from TIG, but unless you have a business need or a burining desire, you can do virtualy anything you want in the welding world with a 251.
    3,341
    Quote Originally Posted by hankj
    That is true but if you want no burnthough on thin material and also no spatter, tig is the best way for aluminun. There is no way around those two issues with standard mig aluminum welding. There are other issues you can work around but why bother when a good ac tig machine just is better overall setup for most aluminum work.
