Any tips on how to braze 2 7/8 to 4 inch OD ( 1/4 inch wall ) using a oxy/ace outfit.
What size of tip?
What should my oxy/ace be set to 3psi?
What should I use for my solder?
What is the techique?
Or am I wasting my time? I don't have a stick welder and can't afford one at this time ( a good welder ). I thought about renting one but it's been 15-20 years since I've burned any rods. I would be lucky if I could remeber how to strike an arc at this point
It's round steel pipe, and I cut the 2 7/8 to butt up to the 4 inch. Basically I am building pulling post for a barbwire fence ( 4 inch round post with 2 7/8 round brakets )
Lots of tubes have been brazed for heavy duty applications, but the fumes from the flux aren't conducive to good vision while brazing, and I think brazing is harder to learn than welding. I agree with Dave, I think it would be easier to weld it.
Victor recommends the following pressures depending on tip size and metal being welded:
#3 tip for 1/8"-3/16" thick set Oxygen 4-7 and Acetylene 3-6
#4 tip for 3/16"-1/4" thick, set Oxygen 5-10 and Acetylene 4-7
#5 tip for 1/4"-1/2" thick, set Oxygen 6-12 and Acetylene 5-8
I got this from their Acetylene welding nozzle and cutting tip pocket data card. Their part # is 56-0411. Got it free from a welding supply several years ago. Data is close enough for most torches.
