Results 1 to 8 of 8
    Jun 2004
    atlanta ga
    84
    Question ??tubing notchers -- band saw??
    im am starting a marine fabrication shop. i will be making boat tops, and marine accesories. i was wondering if anyone knows of a good tubing notcher and band saw. im not afraid of spending alot of money for a good product but if i dont have to spent alot then i dont want to. can any one help?? thanx..
    Houston, Texas
    3,689
    If you are talking 4"x6" bandsaw the Jet is a good one to consider. Tubing notchers are either hole-saw or punch type.
    Williams Lo-Buck ( http://www.lowbucktools.com/index.htm ) sells the punch type. Several places sell the hole saw style. Eastwood is one. http://www.eastwoodco.com/aspfiles/d...02121512003572
    Nov 2003
    O'Fallon, MO
    899
    Check out MittlerBrothers. They have some slick tools since $isn't an issue at this point. Some tubing notchers have limitations as to the degree you can fishmouth. As far as bandsaws, I am looking at Jet as well, but there is a Dake bandsaw that is looking mighty nice. I am going to an auction soon so I will check out what is there before I drop the coin on new equipment.
    Clark County, NV
    5,078
    Definitely check out the Williams Lo-Buck notcher. It's everything BUT "low buck" but I think you will be impressed.
    I've been impressed with Grizzly equipment, especially with their selection. I'd like to have eventually gotten their swivel mitering bandsaw. I thought it was a great deal.
    Oct 2002
    Raleigh
    368
    I guess it all depends if you really want to jump into this with both feet or start slow. You can spend 50$ on the typical drill press operated tubing notcher or $300 for the williams lowbuck mechanical one. Then there are the abrasive belt ones that agressively grind the shape and even more expensive are the ones that use a big end mill in essentially a lathe head and a cross feed mechanism to lock your tube at whatever angle you want and then feed it into the cutter. If time is money and you plan to cut hundreds/thousands and need them quick and accurate you will probably have to spend the bigger dollars for one.
    The miller road show they had here in Raleigh had some really neat cutters in all price ranges from $75 to probably $4,000. The hydraulic versions of the williams lowbuck ones sure were neat (and quick). Clarification... they really were not williams lowbuck notchers. Same idea though. Male/female punch dies but run by hydraulics. Nice compact little units if I remember correctly.
    Houston,TX
    90
    Britton
    Hey Britton you mean stuff like this.
    Shoot me a email we'll talk.
    Jun 2004
    atlanta ga
    84
    Thumbs up THANKS
    thanks for the help, CJM yeah thats what i will be building .it wouldnt let me e-mail u.
    Houston,TX
    90
    Britton
    I sent you mail but if it didnt work mine is omcchuck@ev1.net
    I have some contacts you may be interested in and maybe you have some I might want to know about. Where do you live?
