Results 1 to 8 of 8
    Oct 2002
    wright city, mo.
    230
    here is pic of hacksaw, hope it works this time
    of course i have a modern saw,
    but this one is an antique i have
    had for many years, and it still
    works great.
    wlbrown
    Altoona, Iowa
    583
    Power Hacksaw
    Wow!
    Quite a unit. The one I had some years ago wasn't quite this big.
    Grand Ledge, Michigan
    246
    wlbrown,
    Glad you resolved your problem with posting pictures.
    Do you know when the saw was made? It looks like it has a lot of good years left.
    Oct 2002
    wright city, mo.
    230
    hacksaw
    i don't know when it was made,
    but the patent date is may 1912.
    it had to have been made about
    1920-1925, because my father
    bought this machine from the
    company he worked for in 1957,
    when they "retired" it.
    he went to work for this company
    in 1926, and he said this machine
    was there when he started.
    wlbrown
    Did your father install electric motor?
    Oct 2002
    wright city, mo.
    230
    ROGER,
    not quite sure what you mean.
    i was the one that installed the
    motor. it is a 1hp ring oiled motor.
    this saw is unusual in my opinion.
    the motor is started, it is connected
    to the saw with a flat belt, that runs
    an idler pulley. the part is put in the
    vise, and the frame that has the saw
    blade is brought down, and the handle
    located in about the center of the picture
    is pulled forward. this "shifts" the belt
    to the other pulley, and the saw cuts, and
    feeds down. when the part is cut off, the
    saw comes back up, and stops, but of course
    the motor is still running. hope this
    explanation is clear.
    wlbrown
    Your saw was driven by flat belt from lineshaft system which could have been powered by water wheel, steam engine, or electric motor.
    http://www.old-engine.com/belts.htm
    western ny state
    281
    If you look hard at the picture and then close your eyes you can hear the belts slapping overhead. Either you went back in time or you are visiting the Amish.
    bitternut
