Results 1 to 12 of 12
Thread: Gate Project
    75
    Gate Project
    I am currently in the process of construction a gate that will fit in a 44" space. I want to use hammered tubing for its look, but i am having trouble calculating how far the middle bars need to be from each other to be exactly even. I plan to use 1 3/16 hammered 16 gauge tubing as the outside frame and 3/4" hammered tubing for the inside bars. I also want to add a vine like thing with roses etc. on the front. Is there any program or anything i could use to figure out what i need and spacing. Has anyone done this kind of thing before. THanks, HW
    maple ridge, BC
    92
    get a tape measure and brush up on grade 4 math
    AmaC
    MM175
    O/A torches
    snap on everything
    Texas
    88
    How tall are you going to make the gate? When you say its going to fill a 44'' space im assuming your meaning width wise am i right?
    - John Deere
    75
    yeah the width of the gate will be 44" and it will probably be about 5 feet high.
    Take your inside dimension, devide by the number of spaces...this will give you the center to center distance, of the pickets. Change the number of spaces untill you get a dimension you like. Not rocket science.
    PRK, USA
    699
    Hobby,
    Rocky's absolutely correct. Of course, I think I'd divide by the width of my desired spacing to get the number of pickets but that's tomato vs. tomahto, I guess.
    Here it's broken down in case you're not real comfortable using center to center distances and offsetting half your picket width.
    Assuming your outside dimension is 44"
    44" - 2*1 3/16 = 41.625
    Let's assume you want your picket spacing somewhat under 4 inches.
    41.625/4 = 10.40625 SPACES
    We can probably round this down to 10 but will be checking it later.
    So, we take the number of pickets (which is one less than the number of spaces (9)),
    subtract their width from the space to fill
    41.625 - 9*0.75 =34.875
    and then divide by the number of spaces we need to get our spacing between pickets.
    34.875/10 = 3.4875.
    May as well be 3.5"
    That's close to our spacing desire of less than 4 inches. We also got lucky and will be able to use a couple pieces of 2x4 to space out our pickets.
    You'll be off an 1/8 by using a 3.5" spacing. Where to make it up is your choice.
    (3.5+0.75)*9 + 3.5 = 41.75
    41.75 - 41.625 = 1/8 off over the width.
    You can layout the whole gate with 2x4 spacers and check the look before you weld any pickets in.
    If you want to go wider, 8 pickets gives:
    41.625-8*0.75 =35.625
    35.625/9 = 3.958
    That's real close to 4 inches spacing.
    To check
    (3.958+.75)*8 + 3.958 = 41.622
    May 2004
    Kamloops, B.C. Canada
    32
    You boys are just too kind! Do you think Hobbywelder'll need a tad of space for hinges and a latch?
    PRK, USA
    699
    Who knows?
    First he said opening size then he said, "yeah the width of the gate will be 44""
    75
    Thanks guys this helps a lot!
    HW be sure you have at least a half inch of space on both sides of the gate...more depending on what latch you use. You won't be able to get a 44" gate into a 44" space....well you might get it in there, but it won't open. Just a thought.
    75
    Thanks Rocky,
    I have one more question: What is the best place to buy hammered square tubing for the best price.
    HW
    Nov 2003
    Birch Island BC
    1,197
    Well since you don't post your location the closest place you can find it would be the best. For the amount you need a short drive will eat up a10 % price difference. Terry
