Results 1 to 11 of 11
    Jul 2003
    pac.nw
    311
    off topic. what type of oil for pressure washer?
    alright guys, after looking all over the web and getting nowhere, I've come to the one site where I always get great answers.
    I borrowed a intek pressure washer and it has a Briggs & Stratton engine. It takes regular gas and oil. it's a four stroke, same type of engine that would go in a lawnmower I think. six horse power.
    I need to know what type of oil to put in it. the guy I borrowed it from doesn't know and I can't find a users manual anywhere.
    Jun 2003
    SLC, UT
    4
    for the one at my old work we would always use 30wt nondetergent oil and it aways worked fine...different brand washer but same enigne as that one...
    Jul 2003
    pac.nw
    311
    is that the same type of oil one would use for a car?
    Dec 2002
    st. louis
    9
    Yep, same type
    Feb 2004
    Austin TX
    4,861
    Are you talking about oil for the engine, or oil for the pump? You don't want to use engine oil in the pump. Here's a link that may be helpful:
    Norther Tool FAQ
    Jul 2003
    pac.nw
    311
    Norther Tool FAQ
    thanks for the link.
    I don't know if it's for the pump or what. there is a cap on top of the engine that says 'oil' and it has a dip stick attatched to it.
    I sent the wife to the store to get oil so she'll ask the sales guy what we need. I'm sure it will be a bit more expensive then buying it elsewhere but I'll know for the next time.
    thanks again guys.
    Dec 2003
    Brownwood, Texas
    186
    I use 10W30 in mine , same as I use in the car.
    Feb 2004
    Austin TX
    4,861
    That sounds like the engine oil then. No problem using automotive oils in that, straight 30W or a narrow multi-vis like 10W-30.
    The oil for the pump is separate and you don't want to use automotive oil in that because of detergents and additives in engine oil. It's probably filled through a pipe plug or other hex fitting on the pump body itself, and might have a sight glass for oil level rather than a dipstick.
    Brethren, Mi
    11,272
    Yes, some pumps use gear lube and some use comp oil, but any engine oil will suffice. Summer straight 30 wt is usually preffered in small engines.
    Dec 2002
    Houston, Texas
    3,683
    Sberry is correct; straight 30 weight, but go with the high detergent. Non-detergent was used in the old days but detergent oil is recommended for newer engines. multi grade oils can increase oil usage.
    Brethren, Mi
    11,272
    If I borrowed an engine and it was low on oil it would get changed. These little engines hold a qt and change often and before storage doesnt hurt anything as well as adding stabil to the gas.
