I have a piece of 13'' dia steel pipe that I might have found a use for. I mainly run around fixing farm machinary. anyway I thought a rod oven might be nice to have mainly for my 7018 rods. I think I'll burn hedge and oak in the pipe for heat. The pipe will lay horizontal but I don't know how to put the rods in the fire I have some old rod canasters with the pop-on lids. If I made a shelf inside to hold the canasters closed one end of the pipe and put a door on the other end and a ''chimney'' at the closed end.
Do you think it would work or would the wood smoke contamanate the flux if it got in the canaster. Just an idea so far thought I would ask before I tried it.
