Page 1 of 4 1 2 3 ... LastLast
Results 1 to 15 of 59
Thread: grinders?
    Jul 2012
    254
    grinders?
    Someone probably talked about these before i got here but im gonna buy a name brand grinder im leaning toward a dewalt but can anyone give me their 2 cents about grinders and which brand is better? Bosch seems good and so does makita but ive only used cheap grinders until i buy a new one.
    Miller Trailblazer 251
    Lincoln Electric Pro-Core 125
    14''chop saw
    7 inch grinder,2-4.5 inch grinders,electric die grinder
    half inch drill
    And alot of hand tools
    Nov 2010
    Maryland
    882
    I think most of them are a reasonable bet. I have a Ryobi 4 inch grinder that I bought in 1990 during a truck repair project. The button to stop the shaft from turning (so the wheel nut can be removed) is broken but it's lived through tough use. Even the $20 cheapo's from the dear departed Central Tractor refuse to die.
    The one with the most torque was a Hitachi on sale at Costco for $30; it is a 4 1/2". And a few days ago I picked up a Harbor Freight for $15 just to see how good or bad it was, brand was Drill Master, a house brand I guess. It works quite well and will probably last a long time. One thing I'll say about the cheap stuff from China is that they all seem to pack a spare set of brushes and a few have gone through the original set and were replaced. It took ten or more years of hobbyist use for the first ones to wear away so I got my money's worth. I'm not a big booster of "inexpensive" Far East stuff but these have been good.
    CanoeCruiser
    Harris dual-stage O/A
    Lincoln AC/DC buzzbox
    Hobart IronMan 210
    Lincoln PowerMig 135
    Miller 3035 spoolgun
    Thermal Arc 185
    Thermadyne Cutmaster 52
    Jul 2012
    1,438
    Been trying to break a 4-1/2 Craftsman for 10 years, so so good....
    Dale
    11,593
    Joe, I know you are a budget and I can get bashed for this but it comes from some real experience not just whizzing one one day. Do yourself a big favor, go to Walmarts and spring 30$ for the B&D 4 1/2, I got a whole box full of carcasses, the design things just fell together on this item, doesn't mean all BD things are great but this is tough as nails and outlasted several yellow, I got tired of buying them. Its based on the same chassis, its about as good as any grinder I have ever used in this class and the kicker is the cost. There are a couple other maniacs on here said they beat them like rented mules too and they are still going.
    I am pretty much a daily driver with a grinder, we tested this on the bench, not only one guy using it but at a level no hobby type could ever match. Never overheated it, between that anbrushch wear is what takes them out. This is not a firestorm but the model is 7750.
    Mar 2010
    SE Michigan
    2,084
    Quote Originally Posted by Sberry View Post
    I have one as well. Came from Lowes and it wasn't very much. You can't kill it. I don't think it has stored smoke like the Chinese Harbor Fright stuff does, it never even gets warm......Only drawback I can see is the gears are a bit noisy.
    Great cheap grinder
    www.flipmeisters.com
    Harris OA
    Nov 2010
    Maryland
    882
    Two nice things about cheap grinders is you can have one for cutoff disks, another for grinders, another for a flap wheel, etc. Really convenient to just grab the right tool instead of changing wheels or pushing the wrong one. Second, it spreads the workload across a bunch of them. Finally if one breaks you have backups in a pinch. Okay, three things.......
    CanoeCruiser
    Hobart IronMan 210
    Thermal Arc 185
    Jun 2012
    Arkansas
    105
    Here are the companies that "StanleyBlack and Decker" owns: (pretty much everybody)
    http://www.stanleyblackanddecker.com...ces/our-brands
    S.E. Wisconsin
    5,704
    Lightbulb
    A few years back I worked in a large-work fab-shop.
    They litteraly burned out several grinders a month.
    Three shifts 6 day weeks.
    Most were top name, attempts at rebuilding worked sometimes
    other times not. I made a point of checking out the carcasses
    as there was no maintainance crew on 2nd shift.
    I noticed that just the "luck-O-the draw" seemed to matter as much
    as anything else. Some had been under-greased from the factory.
    I saw a few that looked as if they had been forced together
    in assembly. Tollerence stacking can kill any tool out of the box.
    SO
    Might as well follow the advice above. Plenty of evidence to suggest
    these can hold up as well as the $pen$ive ones.
    ViceGrip
    Negative people have a problem for every solution
    Apr 2009
    houston pa
    1,508
    i have a craftsman 4" from the late 80's that just wont quit. i got a 7" a few years ago that i have been well pleased with. you can kill anything pretty easy if youre not the guy paying for it. i have napa ingersoll rand, milwaukee and metabo. i cant find much fault with any.
    i dont know where b&d are made these days but 20 years ago i liked their power tools and thought their German made drill bits where some of the finest i ever used....i still have a broken set that i cherish.
    Nov 2010
    Maryland
    882
    There seem to be two broad price categories for the little electric angle grinders:
    From $15-20 to about $60 to $70; this spans the Horror Freight ones to big-box store DeWalts, Makita, etc.
    And then the Metabo line at about $180 or so at tool boutiques.
    I wonder how the Metabo feels and handles, and if any are actually sold at that price.
    Has anyone on this forum used the Metabo grinders, and are they noticeably better than the stampeding herd the rest of us use?
    Edit: I see Mike has a Metabo. Shine the light into the dark recesses of our alleged minds!
    Last edited by canoecruiser; 09-29-2012 at 08:35 PM. Reason: Because Grasshopper wants to know.
    CanoeCruiser
    Hobart IronMan 210
    Thermal Arc 185
    Jul 2012
    254
    i forgot about being cheap lol and went to homedepot and bought a dewalt 94 bucks and its got plenty of power but the gear case gets hot quick so im unsure about it my welder friend said its a break in period and i opened up the case and checked the grease on the gears its bare minamal grease so im gonna slather it in new grease and grind on if it not grind till it breaks return it and get another one.
    14''chop saw
    half inch drill
    Nov 2010
    Maryland
    882
    FCJoe, I noticed the same thing you and VG did....greasing the bevel gears seems to be optional at the manufacturer and I've greased 'em up too.
    CanoeCruiser
    Hobart IronMan 210
    Thermal Arc 185
    Oct 2006
    Melbourne, Australia.
    368
    Hi, too much grease, as in packed to the rafters etc and they will run hot.
    All gear cases with grease packs should only be loaded to 2/3rd full to give the grease room to circulate.
    Ian.
    Jul 2012
    11
    what type of grease is everyone using ?
    S.E. Wisconsin
    5,704
    You can't go wrong with a tub of wheel-bearing grease.
    Has the greatest ristance to hardening, and is "heat-seeking".
    If you have a tool that runs hot, the only drawback could be
    a little weapage, as wheel-bearing grease gets a little runny
    as it gets hot, and may find a place to escape a little.
    Phil
    ViceGrip
