Results 1 to 15 of 15
    Jun 2012
    Molalla, OR
    353
    What size of bottles?
    So, i have a Harris oxy-acetylene torch set, has everything except the bottles. And i would like to get an 80 cf oxygen and a #3 size airgas bottle (v75 i think). Now i actually plan to do a lot of O/A welding and cutting. Are they to small or the right size?
    Eastwood MIG135, never fails to make me wonder.
    Lincoln idealarc 300/250: runs like it was made today. Looks like its seen some better days. Origin is Ashland lumber mill. Ready to go. Needs some new leads and a little specialty TLC.
    DEWALT 4 1/2" angle grinder
    Harris oxyacetylene set, no bottle though
    youtube channel :
    http://m.youtube.com/#/user/Hobbywelder617
    May 2005
    Richmond, Virginia
    5,319
    With the 1/7 withdrawal rate (some recommend 1/10), a small Acet bottle will limit you to thin metal. Get a tip chart that shows the CFH used for various tips and thicknesses and use that as a guide.
    We have about a 200 CF bottle which is good for cutting to about 2" and welding to about 3/8".
    DialArc 250
    SyncroWave 250 w/Coolmate 3
    SP-175+
    TA 161STL
    Lincwelder AC180C circa 1950
    Victor & Smith's O/A
    Dayton (Miller) spot welder
    1200 sq.ft. of garage filled with crap
    A kid that can actually run the stuff +++
    May 2003
    Suffolk Virginia
    1,734
    Another alternative for cutting would be to buy a propane cutting tip and use propane. You can't weld with propane, but there's no restrictionon withdrawl rates. A lot of burners and scrappers use propane.
    Blacksmith
    Stickmate LX AC/DC
    Big cheap (Chinese) Anvil
    Hand cranked coal forge
    Freon bottle propane forge
    HH 210 and bottle of C25
    Nov 2010
    Maryland
    470
    If you're going to do a lot of cutting you will use way more oxygen than acetylene. An 80 cf bottle is far too small to have them drain off at about the same rate with a 75 acet. I use a B acetylene (40cf) and an 80 oxygen which is the largest my gas supplier sells for an owner bottle. My O/A is 95% cutting use. The plasma cutter doesn't travel well.
    If you work in a shop setting it could be even more; in a past life I was in a company that did on-site work and we went through lots of oxygen. Turns out on Monday mornings the crews would throw a small O/A rig in the back of the 1-tons and pass the cutting handle through the passenger window and hit off it going down the road. Works wonders for taking the sting out of hangovers. The owners were WTF are we using so much? Finally just swapped out the 60cf for 80's. Some things you just can't fight.
    Not saying you'll have that problem....
    CanoeCruiser
    Harris dual-stage O/A
    Lincoln AC/DC buzzbox
    Hobart IM210
    Lincoln PM135
    Miller 3035 spoolgun
    Thermal Arc 185
    Thermadyne Cutmaster 52
    Angle grinders, vicegrips, the usual suspects
    Two hands, tired body, not enough time...
    May 2009
    Gulfport, Florida
    1,963
    Thumbs up "Blue Wrench"
    I am using propane 20 and 30 pound cylinders, the oxygen size I have is 125 and 150 cf bottles. That is a great combination for me and even tho it don't allow me to weld, I can still braze with it when need be. But I do 98% cutting/heating with it anyway.
    Jun 2007
    Elsewhere
    339
    I will not comment on aircrew and maintainers switching regulators to "100%" and "Test Mask" on the morning after, "back in The Day".
    Aug 2012
    Graham, Texas
    23
    Bottles
    I have an 80 and a number 3 bottles and they do me just fine, I dont use them unless I have to but the will last a good while. I plan on upgrading to the next size up some day .......If you are planning on using them everyday I would say to get the biggest ones that they have. Just my opinion
    Hobart LX 253 Stickmate AC/DC run With a 6500 Watt Powermate Generator
    PowerKraft 230 AC Welder
    Cutting Torch
    A Grinder or 3 and a Chop Saw
    Bunch of cheap Harbor freight Tools
    and A Partridge in a Pear Tree
    Jack of all Trades - Master of None
    Independently Poor
    Graduated 6 Grade (Magna Cum Laude)
    Jun 2012
    Arkansas
    117
    Quote Originally Posted by monckywrench View Post
    I recall some TAC pilots stashing "bailout bottles" and masks in their lockers for use while suiting up
    Jun 2007
    Elsewhere
    339
    "TAC Trained Killers" represent, yo!
    Oct 2012
    3
    Is a 130 CuFt Acetylene bottle (8" diameter, 30" tall to the neck) a good match for a 251 CuFt Oxygen bottle (Size 5, also known as size K)?
    May 2005
    Richmond, Virginia
    5,319
    Quote Originally Posted by Charles Brown View Post
    It depends whether you are mostly heating/welding/brazing or mostly cutting, the latter using a LOT of Oxygen. 2:1 O:A isn't a bad match.
    DialArc 250
    SP-175+
    TA 161STL
    PCB, Fl
    3,942
    Best to have 2 sets of gas bottles one set in use and 2nd set standby. This lets you use most all of gas in bottles and not worry about running out. Keep a little gas pressure in empty gas bottles to help keep out contaminates.
    Roger
    Mar 2010
    SE Michigan
    2,049
    Is that like enjoying a Reddi-Whip can with no Reddi-Whip?
    So little time...So many machine tools.........
    www.flipmeisters.com
    Miller, Hobart & Lincoln TIG/MIG/-
    Hypertherm Plasma (Thanks Jim)
    Plasma-Cam DHC (coming shortly)
    Harris OA
    Too many motorcycles.............-
    Oct 2012
    3
    Quote Originally Posted by Roger View Post
    Roger, I can understand how having double sets of bottles MIGHT keep one from worrying about running out... provided the second set was indeed full.
    How does having a second set of bottles help use most all of the gas in the first set of bottles?
    Is it a psychological or trip efficiency matter of when running out of O, but still having some A left, one can just replace the O without going to the gas supply house, because if going to the trouble to take the trip to the gas supply house, one might as well replace the A, even though there is more A left than O?
    PCB, Fl
    3,942
    Sure I can use all of the gas without having standing by replacement gas. I would then have more than 1hour round trip during business hours to get more Acetylene or O2. One gas always runs out before the other. Just refill that cylinder or both is easy. You pay the same regardless of amount left in cylinder. Maybe you don't worry about running out because that doesn't matter to you. When my truck is refilled I only pay for gallons of gasoline add to tank but they would love to charge me for 20 gallons full tank $80.00 when I only added 10 gallons. Maybe that doesn't matter to you when gas dealer does that for 1/2 full gas cylinder. Don't carrying these Acetylene and O2 gas cylinders inside of your car if you care about your life.
    Roger
