Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 34
  1. #16
    11,282
    First we want to convert it, now we are going to improve it.
  2. #17
    Mar 2010
    SE Michigan
    2,046
    Are we referring to Lucas electrics on the welder?
    www.flipmeisters.com
    Harris OA
  3. #18
    Nov 2010
    Maryland
    470
    This problem is most-easily solved with a small rectangle of plastic printed with "Visa" or "Mastercard". Take same to your favorite LWS. The rest is obvious......
    CanoeCruiser
    Harris dual-stage O/A
    Lincoln AC/DC buzzbox
    Hobart IM210
    Lincoln PM135
    Miller 3035 spoolgun
    Thermal Arc 185
    Thermadyne Cutmaster 52
  4. #19
    Suffolk Virginia
    1,734
    Quote Originally Posted by Sberry View Post
    For the old-timers, it's like Moody/Moody II all over again. There are so many ways for this to go wrong, from electrical insulation failure in the transformer due to voltage punture or thermal stress, to really poor welding performance from mismatched capacitance and inductance, to the possibility of injury or death.
    Blacksmith
    Big cheap (Chinese) Anvil
    Hand cranked coal forge
    Freon bottle propane forge
    HH 210 and bottle of C25
  5. #20
    Jun 2012
    42
    The only way I is to try...
    Some concerns I have.
    The voltage at the transformer would almost double! so that's from 28V to like 56 Volts! Not good.
    The fan
    The 24V that goes to the gun trigger
    The motor speed
    The difference in voltage between each voltage setting would be like night and day with only 4 selections.
    The rectifier.... can it handle 220V?
    So yeah.. there are some concerns.. but wit the right components it should be doable.
  6. #21
    Los Angeles
    5,476
    Quote Originally Posted by Blacksmith View Post
    Indeed.
    MM252
    MM211
    SO 2020 Bender
  7. #22
    Los Angeles
    5,476
    Quote Originally Posted by M20 View Post
    The fan
    The motor speed
    Of course it's doable since they already exist- fabricate one if you want, like you said.. only way is if you try.
    MM252
    MM211
    SO 2020 Bender
  8. #23
    5,317
    M20, with the right components, it would have been a 220V welder already. Let's replace the fan and the primary transformer, maybe one or two other minor things. That means you just replaced about everything that is of value in there. Doubling the voltage should not peel the paint or wreck the insulation, which is good from an appearance and olfactory point of view. Unless you smoke the transformer varnish from too much heat ...
    I do miss Moody. He could take more abuse than even the toughest brands of welding equipment. With a smile ...
    M20 - you're not a reincarnation of Moody, are you?
  9. #24
    Aug 2003
    Gillette, WY
    2,266
    Wonder whatever happened to Moody? Guess we'll have to do with Moody V2.0.
  10. #25
    Nov 2010
    Maryland
    470
    Then there was the wannabe engineering student with the aluminum-oxide jonboat h e l l bent on fixing it with a fluxcore welder. Wouldn't take no for an answer.
    That was a fun thread to read.
    CanoeCruiser
    Hobart IM210
    Lincoln PM135
    Thermal Arc 185
  11. #26
    Suffolk Virginia
    1,734
    Quote Originally Posted by canoecruiser View Post
    That's kind of abrasive, don't you think ...
    Blacksmith
  12. #27
    11,282
    I am with Broc, go for it. I wouldnt mind seeing this.
  13. #28
    Central Oregon
    1,788
    Stick to the 4th for your firework viewing, Safer!
  14. #29
    Nov 2010
    Maryland
    470
    Holy Mohs-es....no axe to grind here. I'll apologize if I caused anyone to grit their teeth.
    CanoeCruiser
    Hobart IM210
    Lincoln PM135
    Thermal Arc 185
  15. #30
    May 2009
    Gulfport, Florida
    1,963
    Quote Originally Posted by Scott V View Post
    Or how about the bright orange light in the sky, rather than the welding machine glowing..
    I am glad this is what I seen in the sky 6:30 this morning and not one of my machines..
