Results 1 to 4 of 4
    Mar 2011
    Hobart 300 Amp Engine Drive ID
    I recently acquired what appears to be a home built welder generator. Curious as to anyone that might be able to help me figure out more about it. The engine appears to be an early gm. 216 or 235. Any help would be greatly appreciated. Serial # reads DW53133. It's rated at 40 v 300 a @ 1500rpm.
    Other tag information is a SPECS. 839 near the bottom of the nameplate.
    Jul 2010
    5
    Can't help with the machine ID but it sure gives new meaning to the name Buzz "Box".
    Calgary
    824
    Quote Originally Posted by Duramax 6011 View Post
    This appears to be one of the early Hobarts sold as a DIY engine drive project in the 30's to 50's. I believe usmcpop had a copy of a Hobart ad for one of these back in the day, and I have seen a picture of a similar set up on this forum with a Model T rear axle. Will check further.
    Calgary
    824
    Here's the ad mentioned above and if you search here for "Hobart Simplified 300", you can see this and several other similar rigs.
    Screen shot 2012-05-27 at 9.21.25 AM.jpgHome Made Engine Drive from Hobart M250 .jpg
