Results 1 to 7 of 7
    Mar 2012
    Missouri
    20
    Welder cart caster wheel morning project
    here's this morning project , i went to pull out the 110 mig for a coupe little welds and the caster wheel
    went belly up , i thought the 350 lbs. rated wheel would carry the welders fine but i guess not , if the other one goes
    i will turn another wheel and wont have that problem again .
    TS2
    We the unwilling , led by the unknowing
    are doing the impossible , for the ungrateful
    we have done so much with so little for so long
    that we are qualified to do anything with nothing..
    Aug 2003
    Gillette, WY
    2,266
    About time you finally showed that South Bend!
    Maybe rated 350 pounds with 4 wheels.
    Mar 2012
    Missouri
    20
    Machines
    it looks like your running a 9 inch SB and the Jet looks like a 14X40
    correct ,, also that behind the Jet looks like a old Volkwagon bus or parcel van
    am i right on my guesses ??
    my SB is a 1974 13X52 with a 7 ft bed , i got really lucky to get that one as im the second owner
    and it has never been ran like a dog ,, my Mill is a Jet JVM-836-1 i run a 10 hp rotary for my
    three phase .
    TS2
    Quote Originally Posted by Wyoming View Post
    Mar 2012
    Missouri
    20
    dummy
    like a dummy if i would of read your Sig you have the machines listed
    TS2
    S.E. Wisconsin
    4,549
    Quote Originally Posted by ts2 View Post
    TS2
    He didn't list the V-dub hippy-bus thO'
    good eyes !
    You haven't driven pure fun, till you've driven sitt'n right over the left front wheel.
    I luv'd my 67 Econoline. But rear-engine is even better, My Dad had a Greenbrier!
    5,319
    I had a '67 bus back around '72. Great vehicle.
