as a new member here and pretty much everyone has a weld table of some sort
i thought i would show some pics of mine
TS2
24X42X1/2
TS2
24X42X1/2
We the unwilling , led by the unknowing
are doing the impossible , for the ungrateful
we have done so much with so little for so long
that we are qualified to do anything with nothing..
interesting clamps.
i take it since its loaded youre not painting it? i tend to skip paint too.
Interesting. How do you secure the vise mount?
Ken
It looks like you're using the reciever hitch method to mount your vice. I like the clean top you get with this method, but rour small plate that provides a "landing zone" on either side of the vice looks useful. I thought it was an extension of the table until I looked again and saw just the receiver tube and no vice. Nice job!
Blacksmith
Big cheap (Chinese) Anvil
Hand cranked coal forge
Freon bottle propane forge
HH 210 and bottle of C25
Okay, I see the receiver mount now.
Ken
yeah the vise uses 1 1/2 square tubing 1/4 wall and on the vise plate i use solid square that i milled down to slide inside of the tube , in the middle of pic 2 there is a 1 inch square tube that slides out 15 inches and i use it as a handle to move the table around on the two wheels i have mounted ,, i think im going to go ahead and mount 1 swivel wheel on the one side that i can raise and lower then i can just push the table around easier than it is now ,, it still a heavy turd though . my top clamps is made from No# 10 rebar and 3/4 coil bars .
TS2
That is an excellent table. What welder did you use?
I just Luv inovation!!!
Cool
vg
i used the old Lincoln stick welder to put it together
but ive changed it since i posted the pics on here , i went with
steel wheels on the back and swivels on the front , now it's alot easier
to roll around now and added a rack to hang the different grinders on when i need them
. but ive used 3 welders on it so far
the Lincoln stick , the Lincoln 135 mig and the Hobart 250 .
but i dont see no further mods left to do ,
it's done
TS2
What kind of bracing do you have under the main table? I assume it's needed with the slots in there.
Ken
Hello,
under the plate i have 2 # 4 inch channels that come in 6 inches from the end of the table no other brace supports, on my X cross cuts i have 2 inches between each slot , there is no warpage from the table top
plate .
TS2
wheels
holders for grinders
another little cart that i put parts on that's ready to weld
I'm sure there's an obvious explanation which I'll be embarrassed to miss, but what function do the horseshoe-shaped devices on the sides serve?
I also like the carts. Everything is there, it can go to the work and then back to the corner. Food for thought....![]()
CanoeCruiser
Harris dual-stage O/A
Lincoln AC/DC buzzbox
Hobart IM210
Lincoln PM135
Miller 3035 spoolgun
Thermal Arc 185
Thermadyne Cutmaster 52
CanoeCruiser
Hobart IM210
Lincoln PM135
Thermal Arc 185
