Results 1 to 8 of 8
Thread: Tri mix
    Jan 2012
    2
    Tri mix
    Would a tri-mix show the best results laying beads on steel?
    Suffolk Virginia
    1,735
    No. Probably should use C-25. Tri-mix is more for stainless steel.
    Blacksmith
    Big cheap (Chinese) Anvil
    Hand cranked coal forge
    Freon bottle propane forge
    HH 210 and bottle of C25
    Calgary
    829
    Quote Originally Posted by mklewis View Post
    For more than you will ever want to know about welding gases, especially tri-mix, and many other topics, visit this site:
    http://www.weldreality.com/
    Suffolk Virginia
    1,735
    This guy has some BS and wild claims too. For example, Cobalt Boats (premium runabouts) are built in Neodosha Kansas; I've love to have a piece of their boatbuilding business in Kansas.
    Blacksmith
    Tri mix was used to reduce divers decompression time but isn't often used.
    Calgary
    829
    Quote Originally Posted by Blacksmith View Post
    Where exactly, in the mig welding gas section, did you detect the BS? I'm sure Ed (and all the major gas companies) would like to know, and perhaps you can take up his $5000 challenge on their behalf!
    Suffolk Virginia
    1,735
    Maybe I overspoke, but I generally take the lone voice swimming upstream with a grain of salt. I see lots of documentation and MIL-SPEC approved welding procedures that specify C-25 for mild steel. MIL SPEC does not allow short circuit transfer, so it is generally spray transfer. Even this site seems to generally agree on C-25 for mild steel. Maybe that's because as Ed aluded to CO2 is cheaper than argon. And Cobalt does make boats in Kansas.
    Blacksmith
    Calgary
    829
    Ok, I was just wondering, because Ed does have a lot of expertise, especially on trimixes, and much of what he has written (not on the web) is available through the AWS, and they don't generally support BS. Much of Ed's web site is one long infomercial which tend to drown out a lot of excellent learning material on there, and his arrogance leads a lot of viewers to attack.
