Im building a more vertical, tower-like cart that will house my mm 211 and pm 45 plasma along with a 125 cf c25 bottle and a later 125 argon bottle. There will be a bottom drawer to house consumables, gloves, spoolmate, etc. I bought some fancy ball bearing polyurethane with reinforced nylon wheels that can hold 700 pounds each. The casters are 4 inch polyurethane as well. Ill post more pics as I progress.
. After welding different areas to curve the heat, I was able to get it back into perfect square
Actually the build of this cart was influenced from my other crappy cart that was very unsafe to roll and did not have a proper mounting area for the tank. I saw the episode of mythbusters where they severed the valve off of one and it went clean through a brick wall! Scary.
. I'll have to get some more steel and other miscellaneous parts to finish it but its close.
Anyway, I took these pictures about three weeks ago or so and they show the work for the drawer which is riveted aluminum sheet over welded 1/2 in. square tubing. This really makes for a nice sturdy drawer. Since this cart is going to hold about 30-350 pounds worth of gear, I added some angular gussets on the casters for more strength. I added ALOT more since these photos but I will take some more once I am finished which will be definitely this week. I should have it painted hopefully tomorrow or wednesday. I am also looking to add a very loud alarm to my cart. Something that would activate once a perp scum would lift or tilt one welder.
