Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 32
  1. #16
    Jan 2005
    Southern Arizona
    64
    Gear motor part #
    My manual for the HH 135 has a part# 202 708 for the gear motor.
    It's item #44 on the illustrated parts breakdown.
    CW
    Hobart Handler 135
    MM 210
    Lincoln AC 225 Buzz Box
    Lincoln Ranger 10,000
    Jack of all trades, master of none; therefore Broke!
  2. #17
    The are different motor numbers based on serial number so be sure you use your serial number to obtain the correct manual. These motors will draw around 1 amp unloaded.
    Keith
  3. #18
    Jun 2012
    7
    i took my welder to a miller dealer and the told me that the wire feed motor was the problem. they ordered me a new motor,i put it in and it still slows and then stops after about twenty seconds... i think i just wasted 120.00 dollars now what?????
  4. #19
    Calgary
    863
    Quote Originally Posted by tjkball View Post
    Did you have them check Hobart Expert Keith's advice (in post#13 in this thread) re the thermistor and motor? Also, if they don't guarantee repairs they diagnose, they are a pretty shoddy outfit. Have you contacted them
  5. #20
    Jun 2012
    7
    no i havent contacted them but i did jump by the resistor and thats the problem. now where can i get one Thanks!!
  6. #21
    PCB, Fl
    3,940
    Here is source
    http://www.digikey.com/
    Roger
  7. #22
    Calgary
    863
    Rather than attempting to repair it myself, I would be back to the Miller dealer that replaced the motor, asking them for a settlement due to their incompetent performance. Did you ask for the the replaced motor on the first repair, and have you checked it according to Keith's advice? Only if the motor failing CAUSED the thermistor to fail, should you be paying out more money, and then only the cost of the thermistor!
  8. #23
    Jun 2012
    7
    They didnt replace the motor but they did tell me that they thought the motor was bad.They did however order me a new motor and I replaced it.The problem is that the new motor had a different shaft in it and I removed the shaft from the old motor and put it in the new one.So im sure they will say I should have brought it back .But I needed the welder and wanted to get it fixed .Anyway I have a spare motor and a new resistor on its way.Seems like an easy job to replace the resistor , Ill just have to wait for it to come. Thanks for everyones help.
  9. #24
    PCB, Fl
    3,940
    What your calling Resistor is it the PTC1 which is a Thermistor?
    Roger
  10. #25
    Jun 2012
    7
    Yes its the PTC1 I just jumped across it and it worked fine.I ordered a new one from the link you gave me. Shipping was far more than the part. Thanks
  11. #26
    Jan 2009
    11
    motor number please
    Where did you order the motor and what is the part number. My book list the part number as 202-708 but I don't find it anywhere under that part number. An email to midget9999@embarqmail.com would be appreciated.
  12. #27
    Calgary
    863
    Quote Originally Posted by Hobart Expert Keith View Post
    Keith
    Midget9999:
    You probably have to order from Hobart using your serial#.
  13. #28
    Jan 2009
    11
    Motor Number????
    What is partnumber on motor and where did you get it?
    Midget9999
  14. #29
    Dec 2005
    Lodi, CA
    1,236
    owner's manual????
    If you threw it away already, look around on the top line of this page, I'm sure it's available.
    *** Disclaimer ***
    As I have no wish to toy with anybody's life, I suggest you take this and all other posts with a certain amount of skepticism. Carefully evaluate, and if necessary, research on your own any suggestions or advice you might pick up here, especially those from my posts, as I obviously haven't the skill and experience exhibited by some of the more illustrious and more successful members of this forum. I'm not responsible for anything I say, as I drank toxic water when young.
  15. #30
    southern me
    145
    Quote Originally Posted by midget9999 View Post
    The part number you referenced is a valid part number for a drive motor. It is in stock at Miller and any Miller distributor should be able to order out for you. Should be @ $100.
