Newbie welder with a Hobart 210 w/ spoolgun. Really, new at everything. I'm a computer guy who does a little bit of motorcycle maintenance... so this project has me thoroughly whelmed so far. My old sideboxes for my KLR 650 have succumbed to various wipe outs... I think it's time they go in the scrap pile. So for my first project, I'm going to try to build a replacement for them.
Picked up some .090" 6061-T6 at the local metal-place... Sure is pretty...
Had some difficulties moving it into the basement work area without cutting off my toes...
Started marking up the sheet with the planned measurements. The idea was to make as few welds as possible, and just fold the whole thing up and weld the seams. some of you will know the immediate problem with that. :-) I noticed that for some reason, marking up the aluminum really ate through my Sharpies. What do you guys use to draw your guide lines?
Because the sheet was a pain in the *** to work with vertically, I got impatient and started some of my cuts early... wanted to get the sheet cut in half so it would be easier to work with. I used my dewalt jigsaw, a sheet metal blade, and water. Was surprised how well it cut... as long as I kept it cool. I had to file aluminum out of the blade teeth more than once.
After getting a few "waste" corners cut out and the sheet lopped in half, it became much easier to get the lines drawn.
My 11 year old neighbor came over to inspect what all the noise and cussing was about... I showed him how to use the jigsaw and cut out a "box" from one of the waste areas. The plan is to do some welding on pieces like this before tackling the main bit. I figure if I turn everything into scrap, I'll be ok since aluminum seems to go for a pretty good rate out here, but I'd prefer to have a chance of success. :-) I'll fold the sides up, as well as a little rim around the top... and end up making a latching top for it later. The construction would be identical for the sideboxes, except no weird angle cutout for the ground.
Unfortunately, here's where I discovered the T6 part of things... I did a test bend on some small pieces of metal... I hadn't planned on being the one to bend these, since I don't have the equipment for a nice bend. But I wanted to see what I'd need to do before handing off to a shop. Well, clearly there's some annealing that needs to happen... Would a bending shop handle that themselves? What kind of information would they need from me? My original "design" just assumed perfect 90 degree bends (except in two places), which I'm sure would leave some pretty big gaps to weld as it is... Now I'm wondering if that's just a bad idea...
Heating until the sharpie mark went away...
And then bending gave some pretty good results...
These are the boxes I'm looking to replace:
So... Am I on the right track? Should I skip trying to get things bent, and just go for welding the whole thing? Are the gaps that I have to bridge going to totally stump a newbie welder? I've performed a few ugly "repairs" on the old boxes to keep water out of them, and stuck a few pieces of steel together. Just wondering if I've got the right idea for how these should go together...
