Page 3 of 3 FirstFirst 1 2 3
Results 31 to 42 of 42
Thread: Stick Welder
  1. #31
    11,293
    That is a plus with welding/gen sets, way more poop than common generators and one reason I think is engine power, a 6000 might have a 12 hp on it,,, on a welder a 16 hp engine, a 20 on my GS8000. They start motors wayyyyyyyyyyyy bigger than they list in the manual.
  2. #32
    3,341
    I will say I do like my Yamaha 1000 inverter generator also. I am a big fan of using only enough generator for the job. Inverters in general do that very well. (Matches RPM to load, with the freg staying at 60hz at all times) Running my Lincoln 305G (sold) for a few lights, never really appealed to me. 1-2 gallons of gas per day does. Light load for fridge and a few lights is about .66 gals per 12 hours.
    Esab 200 caddymig
    Esab 1600 powercut plasma
    Thermal 186 AC/DC
    Thermal Arc 400 MST(Right stuff!)
    Ultrafeed 1000
    Thermal Scout 170 engine drive. (killer little unit)
    Thermal Pee-wee 85s
    Smith O/A plus mini torch
    Smith machine torch
    LN-25 pro
    LF-72 feeder
    Edwards 65 ton
    5X10 CNC table
    Remember good judgment comes from experience, experience comes from bad judgment.
  3. #33
    11,293
    I use an 8K unit for power and the main reason is the well and have 3 fridges + the misc stuff. I turn off my air comps and 1 water heater if I need to make power, hasn't happened in a long time though. I usually hook it on, turn the well off till any other loads cycle then flip well on and everything is ok after that point. The 8 k is marginal, about 10 would be perfect but it is certainly pricey to keep a machine revved, makes a guy appreciate line power. The poco here has done a lot of repair, finally got to some things that were causing flickers and outs, last interrupt that was more than momentary was about 3 hrs a couple or more years ago. Longest I been down was couple days.
    During a short one I decide to drive up to major store to get a couple things and kill time, the poco said 2 hrs so off I go. I am in HD and run into a neighbor trying to get assistance from elect dept from a guy says he is an electrician, maybe so, but I strongly encourage this guy to get some help, he wants to back feed his property and in a panic. I tell him,,, the power will be on by the time you get home, after he walks away I corner the HD guy, I had a little informing of my own. I say, it should be obvious you are talking to this idiot first and second he has no clue wtf and although I am not the lawsuit type I wont hesitate if this fool tries to hook this up based on advice he got from here and its not a good idea to hand it out when people trying to do something illegal. Not only should you not be helping him but should inform him how dangerous this is,,, multiplied x the dimwit factor. I have nearly grilled myself and have some concept,,, ha
  4. #34
    Suffolk Virginia
    1,736
    I have sucessfully backfed, but I still have a written checklist of steps and cautions and refer to it each and every time. I have no desire to cause injury to anyone or damage anything just to convenience myself.
    Blacksmith
    Big cheap (Chinese) Anvil
    Hand cranked coal forge
    Freon bottle propane forge
    HH 210 and bottle of C25
  5. #35
    Oct 2010
    36
    Where is Thermal Arc 161s manufactured? Are the reliable machines? I have always been a blue fan, but there is a big price difference.
  6. #36
    3,341
    Quote Originally Posted by laman View Post
    China on this one. Not your average China welder. The 95s (little sister) was really put through it's paces before released. I am sure this went through some of the same testing. Mostly in Australia on the 95s. The 95s was outstanding in reliability.
    Esab 200 caddymig
    Thermal 186 AC/DC
    Ultrafeed 1000
    Thermal Pee-wee 85s
    Smith machine torch
    LN-25 pro
    LF-72 feeder
    Edwards 65 ton
    5X10 CNC table
  7. #37
    Jan 2011
    Near Dallas, TX
    46
    Quote Originally Posted by Sberry View Post
    They are designed with low ocv features for safety, the rod needs to have more stabilizers than 6010, hence the 6011 which was designed to be able to be used on buzzers.
    6011, as I understand it, has stabilizers added vs. 6010 to be able to run on AC only welders.
    It's the 7018AC variant that is designed to run on welders with low OCV, vs. standard 7018.
    That's what I have gleaned from all the literature anyway.
    greg
    The truth is out there, but the server's not responding.
  8. #38
    May 2011
    3
    Quote Originally Posted by Brand X View Post
    This is the deal Cary.
    I sold my 95s to my friend and bought this. 100 amps output on stick running on a 120 volt/20 amp circuit.(110 max stick on 120 volts) Plus the option of 220 use. The 95s was 90 amps output on stick. Three year warranty on this compared to one year for the 95s. I have a feeling it will run most rods better then the 95s.
    http://www.ebay.com/itm/THERMAL-ARC-...item53e5eb6922
    Would there be any problems running longer leads on this?
  9. #39
    11,293
    I got another piece of number 4 25 ft long for my Max, wish I would have done it for an earlier job. I like to be able to drag the stinger around for construction type work.
  10. #40
    3,341
    Quote Originally Posted by Graybeard62 View Post
    No, if you go a lot longer then factory, just up the size a bit. 25ft would not be a issue.
    Esab 200 caddymig
    Thermal 186 AC/DC
    Ultrafeed 1000
    Thermal Pee-wee 85s
    Smith machine torch
    LN-25 pro
    LF-72 feeder
    Edwards 65 ton
    5X10 CNC table
  11. #41
    3,341
    I went another way. I still need to get some extra #4 cable. Since I had a few extra male 25 MM dinse laying around, This is a good way to extend the leads. I might buy a 50 ft and cut it in half. That will give me extra length when needed. The Thermal cables are 12ft. I rather keep the power cable short, and extend the leads if using 120 input power.
    http://cgi.ebay.com/ws/eBayISAPI.dll...E:L:OC:US:1123
    Esab 200 caddymig
    Thermal 186 AC/DC
    Ultrafeed 1000
    Thermal Pee-wee 85s
    Smith machine torch
    LN-25 pro
    LF-72 feeder
    Edwards 65 ton
    5X10 CNC table
  12. #42
    11,293
    I ordered a couple connectors and made 25 ft just for the stinger side, that works pretty well. Even though the machine is portable I found it a pain to move 3 things every time something was just out of reach and the 25 plus the factory stinger gave it some range, set it anywhere near the middle of a project and have enough to jump around, trailer building or shelves in my barn, up ladders, each end of the bay etc. I didn't bother with the ground side. Was going to get a 6 due to the fact this would be small stuff usually from 120V but they didn't have it when I grab this up and had 4 in pre-cut, seems it was around a buck a foot or so at a welding store. Maybe 30$ for the piece. I actually had to order connectors, the counter types were about clueless and claim to have half a mill in inventory, big wall full of parts/pieces but you would have thought I was asking for moon rocks.
