Results 1 to 4 of 4
Thread: cylinder carts
    Nov 2002
    North Carolina
    43
    cylinder carts
    I am interested in buliding a cylinder cart for my oxygen/ acetylene cutting outfit, and I was wandering if anyone out there have any unique designs that they would like to share so that I can figure out what I should be building.
    Oct 2002
    southern NJ
    251
    I just use an old furniture dollie and strap the tanks to that. Not real fancy, but it works.
    Here is a link showing how to make gas welding cart. It's real commonly used type of cart.
    http://www.metalwebnews.com/howto/cart1/cart.html
    A local dealer is selling more of a soft ground cart that uses folding spare tires that are common at junk yards. The hub for that cart is about 5"X5"X1/4" plate welded to 6"X 1" pipe. Washers and cotter pins hold hub on axle. The plate has holes for bolts to mount wheel/tire and hole for axle. The rest of the bottle cart is a bit beefier than one in llink.
    Houston
    35
    Like Zach suggested...simple is easy. This one is made so that the dollie can still be used if needed.
    Just an example:
    http://www.hobartwelders.com/mboard/...?s=&postid=121
    Rest of the post can be found here.
    http://www.hobartwelders.com/mboard/...s=&threadid=30
    There are more on this board, try a search or change time limit to see older posts.
    Brent
