Results 1 to 7 of 7
    Jul 2011
    Myrtle Mississippi
    12
    Feed bin dump door
    Need ideas on how to build a dump or unload door on small feed storage bin.It has a funnel shaped bottom,and I welded leg extensions on so I can roll a wheelborrow under it, planning on using 6'' gas pipe, I 'm just not sure how to dump the feed out controllaby, so need a door on 6'' pipe. any ideas are welcome and appreiciated, thanks alot and have a great weekend.
    Miller 212/3035 spool gun Hobart stick mate ac/dc oxy-act HTP 625 micro-cut plasma(12 yr. old son campbellhausfeld Mig) ,HayBudden 75# anvil and custom built coal forge.If I can't build it I don't want it.
    Aug 2003
    Gillette, WY
    2,266
    A quillotine type chute like the one on the picture below will work well enough. Probably easiest to weld a rectangular receiver on the side of the pipe to attach it.
    Jul 2011
    Myrtle Mississippi
    12
    Hey Wyoming,yea I think I like your idea, I'll have to turn it 90 degrees as how mine feeds straight down from the bottom,but I'm sure it will work out, many thanks.
    Suffolk Virginia
    1,733
    My grandfather had a horizontal wooden guillotine in his barn. Dump the grain into the bin in the garage above and then place a pan under the chute down below and jiggle the guillotine to dispense grain and feed the horses. Worked fine for years.
    Blacksmith
    Big cheap (Chinese) Anvil
    Hand cranked coal forge
    Freon bottle propane forge
    HH 210 and bottle of C25
    5,312
    My uncle had a grain wagon like the one Wyoming pictured, but it had a door big enough for us kids to get through. He used it for oats and ear corn. It was hard to shut with the corn.
    Jul 2011
    Myrtle Mississippi
    12
    Well Wyoming,I thank ya once again, that's what I had in mind and it worked out perfect. If I could figure out the pic's I would post one(a little on the ignert side of Hy-Tech) well a rain storm's a coming up, so got to close up the shop, just wanted to say thanks, ya'll have a goodun.
    Aug 2003
    Gillette, WY
    2,266
    Glad it helped. I grew up in the grain business...and never so darned glad to get away from it! Still, you would have been able to come up with the same sort of idea, and picture, had you done a photo search. I use Google Image, but I would imagine there are others equal or better. From memory, I just typed in 'grain bin chute' and there the photo was a few lines down. Give it a try next time around and see if, like me, you don't find it better than trying to re-invent the wheel.
