Results 1 to 2 of 2
    Jul 2011
    Need some advice - steel workbench
    Hello All,
    Looking to replace a plywood workbench with a piece of steel.
    size 3.5ftx7ft
    What thickness should I look for and what is an aver good price for something like this? I was thinking 1/2" would be good and the local steel yard quoted me $300 for a 500lb piece cut to size.
    I'll be mount a vice to the workbench and didn't to get something too thin.
    Any advice?
    Scott
    Last edited by Atticka; 07-12-2011 at 02:07 PM. Reason: Correction on quoted piece
    May 2011
    35
    1/4" or 3/16" will give you a sturdy bench. If you get 1/2", I hope you have a 330 to move it around.
    If your top is flimsy, weld an angle iron frame underneath it to shore it up - 1/8" or 1/4" max.
    Good luck and weld on
