Results 1 to 11 of 11
    Apr 2011
    2
    Argon Bottle Question
    I've only ever welded with Flux Core (0.30) on my Hobart 140. I have now purchased a used 80CF Argon bottle and am ready to convert to MIG. I have two questions, though:
    1. Is the bottle okay for C25? I was reading about valve tubes that are found on Argon/CO2 mixed bottles.
    2. The bottle is exactly half-full with straight Argon (1100PSI). Can I have them fill it to about 1600PSI with straight CO2 to achieve a 75/25 mix?
    Thanks.
    Jun 2010
    North Central Fla
    210
    JP, most LWS gas suppliers exchange bottles when given empties or swap them when going from mixes to straight gasses. Might talk to your local LWS and see what exactly their policy is.
    Bob
    Enough tools to do anything, common sense to use em properly.
    Big nasty scar, no kidneys, so you think you got issues?
    Apr 2011
    2
    Thx
    GTS-Welco was great. They swapped my Aron bottle with a mix, no questions asked. Thanks for the advice.
    Mar 2010
    SE Michigan
    2,043
    My preference is owned bottles, just my preference. I keep my bottles pretty looking. Even have my company name on them.
    www.flipmeisters.com
    Harris OA
    May 2009
    Gulfport, Florida
    1,963
    Flip,
    I don't know what you mean. Please explain.
    Mar 2010
    SE Michigan
    2,043
    Urch...
    The second is pretty, the first needs repainted.
    All mine are green with white lettering. I keep a thin rubber band around the middle so the employees at the refill station don't clang my bottles against adjacent bottles. Keeps the paint from chipping (for the most part)....
    Harris OA
    May 2009
    Gulfport, Florida
    1,963
    Urch...
    Flip,
    I have 5 bottles all owner but I never get them back. I am at the mercy of what they give me.
    I have had crappy ones and I have had almost brand new ones. So painting them would be a waste of time in my case.
    Mar 2010
    SE Michigan
    2,043
    Convenient for me, Airgas has a full service plant just south of me (in Toledo, Ohio). I drop off my bottles and they mark them with a yellow plastic slip over collar and I pick them up the next day, filled.
    I leave the plastic collar on so there is less effort expended (by them) on the refills.
    I've seen some ugly bottles on the rack.
    Only the O2 and the acetylene bottle I have are exchange. Those are usually ugly.....
    Harris OA
    Mar 2011
    dfw metorplex TEXAS :)
    50
    I just swap mine out. I own them it taks me a few years to go thre my little torch bottles.
    the argon bottle I swich out for what ever I need. be it 100% argon, c25 or 100% co
    S.W. Mi.
    413
    I don't sweat the outsides of my cylinders but I do prefer the INSIDES be vacuumed clean
    May 2010
    Worcester, MA
    47
    here here.......
    ESAB OXY-Welding setup
    Millermatic 211
    Millermatic 251
    Miller Dialarc HF
    Miller Dynasty 200DX
    Hobart BetaMig 2510
    Light to industrial fabrication
    6G TIG & Stick
Tags for this Thread
