Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 100
  1. #16
    MD/DC Metro
    392
    Heh… I think I'm going to rig a microswitch on the back of my pedal to open the valve as soon as I start putting my foot down. It should be easy enough to build a post flow delay into the circuit…
    Mark
    (aka: Silverback, WS6 TA, JYDog, 83 Crossfire TA, mpikas, mmp...)
    Bridgeport J-head -- Synchrowave 180 SD -- Hobart Handler 135 -- HTP 38 plasma
    HF bandsaw -- Rigid 4.5” angle grinder (+2 cheapie HF ones)
    BFH
  2. #17
    Oct 2004
    3
    Were to get Parts
    Were are You Getting your Parts From...........I can not find the SCR GE 8493622......................Is there any special place you get every thing else...........I have a foot pedal but have to build the rest.....thanks Bruski36
  3. #18
    Central Kali
    5,292
    http://www.digikey.com/ is a good parts place.
  4. #19
    decatur, al
    1,205
    I got my SCR's from the www.surpluscenter.com for about $16 each I think it was. It looks like they're sold out of them now ...
  5. #20
    Oct 2004
    3
    Will these SCR's work
    Thanks Mike W & Morpheus........
    I found these 2N1792 110amps 700volts rms SCR
    Do you know if these will work?
    One more Question......R4 250k 40% potentiometer ( whats the 40% for)?
    Thanks Bruski36
  6. #21
    Winnipeg
    857
    Quote Originally Posted by bruski36
    Thanks Bruski36
    Those SCR's sound good for this application. Can you get them cheap? As for R4, I used a 1 Meg ohm potentiometer because I couldn't get full on to off with the 1/3 to 1/2 travel my foot pedal was moving it through. Don't worry about the 40%, not sure what that was all about. It needs to be linear taper (not audio), and doesn't need to be very high wattage. It handles very little current.
  7. #22
    Sep 2006
    Franklin, NC
    Talking Need a data sheet for GE 8493622 SCR
    Quote Originally Posted by bruski36 View Post
    Can anyone help me with a data sheet for the SCR GE 8493622 ? Or who made them.
    I have two of them and can get more of them.
  8. #23
    Oct 2007
    15
    I know this thread is a year old or more, but did you ever get this unit working bruski36 ?
    Anone actively using one of these ?
  9. #24
    Nov 2006
    133
    I actually built the circuit a while back, I havnet put it to use yet though. Heres some pics of the board I built.
  10. #25
    Oct 2007
    15
    Tanky, I get a lot of pictures blocked here at work, do you think you could email that one directly ? stragedy AT gmail DOT com .
    If you're not using it, you wanna sell it ?
  11. #26
    Nov 2006
    133
    I sent the pics, and im not planning on selling it, but if anyone wants I could etch a board for them.
  12. #27
    Oct 2007
    15
    Your board looks great, nice thick traces, good layout.
    I like the BioHazard symbols too.
    From that as a starting point I probably wouldn't feel too bad about assembling it myself.
    What did the total of the parts come to ?
  13. #28
    Nov 2006
    133
    I have about $15 in parts for the board, not including the board itself or etching supplies.
    The pot was about $10.
    Everything was from www.mouser.com
  14. #29
    Nov 2004
    231
    I built one of these last year and it didn't work right on my welder. I need to get back at it and try to figure out what went wrong. If anyone out there can give some help please reply, Thanks!!! ohm
  15. #30
    Oct 2007
    15
    Maybe you could post a picture of the circuit you ended up using and how you wired it, and them more knowledgeable on here can pick it apart, see what you did wrong ?
