I have some parts to weld out of 7075 aluminum. I've done some build-up on a part that milled to short with 5356 it worked ok. But joining parts? What's the best filler to use
I didn't think it was weldable...Bob
http://www.esabna.com/us/en/educatio...4-and-7075.cfm
Bob Wright, Grandson of Tee Nee Boat Trailer Founder
Metal Master Fab
Salem, Ohio
Birthplace of the Silver & Deming Drill
http://www.ceilingtrains.com/
http://groups.yahoo.com/group/sawking/
http://groups.yahoo.com/group/southbend10k/
My Alro book shows it can be spot welded but not fusion welded.
4043 is ok, but just ok.
Perhaps we'd be better off if certain posters didn't just "pull an answer out of their azz".
What supporting documentation do we have that 4043 is OK as a filler for 7075?
Seems the OP would be better served by reading the link provided by aametalmaster rather than taking the word of someone "shooting from the hip".
SundownIII
Syncrowave 250DX, Tigrunner![]()
Dynasty 200 DX w/CM 3
MM 251 w/30 A SG![]()
HH 187 Mig![]()
Dialarc 250 w/HF 15-1
Hypertherm PM 1250 Plasma
Victor, Harris, and Smith O/A
Mil Mod 6370-21 Metal Cut Saw
Grizzly 6"x48" Belt Sander
Miller BWE and BWE Dig
Another article:
http://archive.metalformingmagazine....00/06/Alum.pdf
Ok, Here is a copy to support my statement. No azz pulling here.
urch,
PM sent.
My comment was not directed at you in any manner. You and aametalmaster gave the CORRECT answer.
SundownIII
HH 187 Mig![]()
A fundamental part of being a "Metal-Worker" in any capacity,
but especially occupational..............
Is to understand the attributes and quallities of the alloys being sellected.
7075 is the Godzilla of aluminum. Machinabillity out of this world.
Highest strenght possible!! Intended to render a net component..........
............by removal ONLY.......... not build-up or joining.
To attempt welding (joining) this alloy is .....???
An "infraction" to be polite.
vg
I will take this statement back and just say don't under any circumstances try to weld this alloy.
Don't fill holes, or do any kind of build up. Don't repair washed out corners, or dings on 7075 molds and dies. Don't for whatever reason cap off plugs or weld 7075 standoffs to any other 7075 parts or assembly.
Don't do test welds, or any samples, or first articles, or anything else. Don't even try.
Sorry for offering any type of reply.
P.S. Never, ever, under any circumstance try to anneal, bend, weld with 5183, and retemper 7075 to original hardness.
Retired...
Master Electrician
Journeyman Refrigeration Pipefitter
Semi-pro/Hobby Welder
Miller MaxStar150 TIG/Stick Inverter
Miller MM175 MIG
Eastwood Plasma Cutter
Victor Oxy/Acetylene
EMCO Maximat - Super 11 Lathe
Grizzly X3 Mill
You are correct on both counts.
1. I did no research. I shot from the hip from experience.
2. Yes, I repair 7075 molds. Most of them are just plain worn out, and need some buildup to eliminate the flash, hence 4043 and peened to smash possible porosity. Others are missing gates or tabs or need inserts welded, hence preheat and 5183. And some need pockets filled and holes closed.
I will admit 7075 would not be of my choosing for a welded structure.
Posters are referred back to the OP's original comments/questions.
"But joining parts? What's the best filler to use"
No "standard process" is going to yield satisfactory results for joining 7075. The weld may look ok, but it's not.
If "joining" parts is the OP's objective, then it's time for the screws, bolts, or rivets.
SundownIII
HH 187 Mig![]()
