Results 1 to 12 of 12
    Mar 2010
    49221
    12
    .045Hard Surface wire
    I've been thinking about buying some hard surface wire to build up the edge on some tines on an old rotatiller. I asked about the wire at the local store and they have .045 2lb spools setting on the shelf.
    My question is, will it work well in a Handler 210?
    If not I'm going to see about having them order something smaller.
    Mar 2010
    SE Michigan
    2,077
    Good questrion. I usually hard surface using SMAW.
    www.flipmeisters.com
    Harris OA
    Mar 2010
    49221
    12
    not having an arc welder, I did a Google search last spring for "hard surface mig wire"
    the 210 will run 045 flux core wire, 035 solid wire but beings the hard surface just lays on top anyway and I'm not going to use it to try to weld 2 pieces of steel together.
    the 045 wire they have has been setting on their shelf for a wile collecting dust and if their going to sell it at a discount I'll buy it before having them order something smaller. either way, the stuff is not cheap. the price for the 2lb spools they had on the shelf was around $25-30 don't remember exactly
    S.W. Mi.
    413
    For the guys that don't want or need .045 hard facing here is an .035
    http://www.hobartbrothers.com/products/McKay/ARMORWEAR/
    Not cheap....16.00 lb on a 10# but if ya needs it ya needs it
    Mar 2010
    SE Michigan
    2,077
    Interesting. I went and looked at the specification sheet and the wire is listed as highly abrasion resistant. I might try some myself in as much as my local WS is listed as a stocking dealer. Not a big flux core person bit I might run some on the slip shoes on the haybine and compare it to the Abrasoweld I usually use.
    It's real sandy here and steel 'disappears' pretty quick in contact with the ground.
    Harris OA
    S.W. Mi.
    413
    Hobart Fabtuff 960 is what lots of excavators use for repairs and buildups but then your back to .045 again and 30lb spools.
    Mar 2010
    49221
    12
    I had my eye on http://www.thermadyne.com/IM_Uploads...27_Crcw009.pdf
    can be had in 035, 5lb spool and it's not flux core
    Hobart Handler 210
    Hobart AirForce 700i
    S.W. Mi.
    413
    Now there is a head scratcher.....the catalog I have access to shows a revision date of 6/08 and does not show it in .035 but the link page you show has a revise of 1/08 and shows it.
    It is available on the 5# spool and would probably run about 18.00 lb.
    Mar 2010
    49221
    12
    I put that part # in Airgas web site
    http://www.airgas.com/product/inquiry/STO11929200
    It listed under Tubular Wires (FCAW) as a Semi-Automatic Gas Shielded Hard Facing MIG Wire
    Hobart Handler 210
    Mar 2010
    49221
    12
    After more reading:
    which also says "tubular wire"
    the 045 Stoody 101HC-G Current, Amp. DCRP 150 200, should work with the Handler 210, although I may have to swap out the liner, force myself to run shorter beads and take more breaks
    Hobart Handler 210
    Sep 2009
    Kansas
    6
    I've got a HH187 and asked a similar question on another welding site. To summarize what all the posts said..."No. I can't run hardfacing wire with a 187. I'd need a bigger machine."
    Mar 2010
    49221
    12
    you should be able to run gas shielded .035 Stoody 101HC-G in the 5lb plastic spool @ 80-185 amps
    if vwguy3 is correct it would only cost you $90 to try it
    Hobart Handler 210
