Results 1 to 15 of 20
    Dec 2009
    des moines iowa
    122
    stripped allen bolt
    hello im trying to rebuild a gear box on my semi that runs off my pto to drive my pump. I have 2. 5/16" size allen bolts that have stripped out trying to remove them. they are in very tight could not get vis grips to lock on and turn them there is no room. what is there to get them out, i though about welding a bolt into them and using a shocket to remove them or grind the heads off and try to remove them that why the bolts are about 2.5" long
    have
    hobart handler 187
    lots of hand and air tools
    motor lift,motor stand
    2 tall tool boxes
    lots of shop lights
    2 wood stoves "still not enough heat for my 6 car shop"
    6" ginder
    hand ginders
    2 work tables
    14" chopsaw
    drills
    3 floor jacks from 3000 pounds to 33,000 pounds and countless jack stands
    need
    more clamps
    more cutting tools like torches
    Canyon Lake, Texas
    6,627
    Are you sure they were 5/16", and not Metric (which might be why you stripped them)?
    I'd tap a stub of Allen hex in there, the kind that a socket slips over (like my Craftsman Allen 3/8" sockets), give it a short weld right at the bolt, then slip the socket over and wrench it out. The heat from the weld should free the bolt.
    Dec 2009
    des moines iowa
    122
    pertty sure got all the others out find these to was rusted in and i could not get them with a braker bar so i used my impact on a allen shocket which was just alittle more then the head of the bolt could take after the last builder over tighted them to 200 + foot pounds
    have
    hobart handler 187
    2 tall tool boxes
    lots of shop lights
    6" ginder
    hand ginders
    2 work tables
    14" chopsaw
    drills
    need
    more clamps
    Nov 2010
    Tampa Bay, FL
    42
    If you have an air hammer, put a good chisel on it and hit top of the head at an angle. That should break it loose, if space allows.
    Mar 2010
    SE Michigan
    2,049
    A shot in the dark....
    You say semi, so I presume you have a wet kit on your tractor and we'll presume it's a diesel and also presume it has some model of RoadRanger (Eaton) transmission. If so, the PTO drive is on the side, secured by 4 bolts that should have been hex capscrews, not socket head cap screws (aka allen head). If you twisted the heads off you should still be able to remove the pto drive casting and then weld on the end of a hex capscrew and back out the broken bolt shank. Welding on the top of a hex capscrew will loosen the stud via the weld heat, allowing you to back out the broken bolt.
    Don't forget to set the preload when you put it back together.
    Just being presumptious.................
    www.flipmeisters.com
    Harris OA
    Feb 2005
    141
    you could clip a tiny piece of bronze and some flux in the hole and then place the allan wrench on it. heat allen head till bronze liquidfies. let cool and then turn remove bolt.
    on the bigger allen wrenches, it won't bond to the wrench due to the wrench not getting hot enough. The bronze will bond to the allen bolt because it is hot enough. you now have a perfect fit and most of the time you won't have to sacrifice a good allen wrench.
    Jun 2006
    Wichita, KS, USA
    4,102
    Thumbs up
    Quote Originally Posted by Scott Young View Post
    Scott, that's a neat idea! I'll tuck that away for when I need it.
    MM180
    SP125+
    MI
    1,012
    a punch or chisel whacking the bolt head ccw will loosen some really stubborn stuff. Get it good and sharp so it digs into the head for a solid impact. I always try this first if possible, as it has no chance for heat damage to anythng, and usually is availible with the tools directly at hand.
    Dec 2009
    des moines iowa
    122
    yes you are right about the truck. but its not my pto its my gearbox that my pto runs. i have a gearbox to make a 90* turn to my vaccum pump from the pto. what i ended up doing is welding a bolt to and got it out and the other i had to cut the head of the bolt off to take the load off it to turn it out
    have
    hobart handler 187
    2 tall tool boxes
    lots of shop lights
    6" ginder
    hand ginders
    2 work tables
    14" chopsaw
    drills
    need
    more clamps
    Mar 2010
    SE Michigan
    2,049
    Ah, you have an air can. Of course you have a big black rubber mallet too.
    I work on wet kits ocassionally (we have 2 tractors with wet kits for roll off's).
    You still need to loose the socket head capscrews and replace them with high strength hex caps. Recessed hex caps have no place on a working truck. They fill with crud and are a PITA to work with.
    Harris OA
    Dec 2009
    des moines iowa
    122
    x2 all bolts on trucks should be hex head bolts like you said allens have no place in a work truck they just dont stand up to the needs of the job
    have
    hobart handler 187
    2 tall tool boxes
    lots of shop lights
    6" ginder
    hand ginders
    2 work tables
    14" chopsaw
    drills
    need
    more clamps
    S.E. Wisconsin
    4,549
    In concept I understand, the point of the two previous posts.
    It's common sence, realy.
    BUT:
    To clear up one thing.
    Should any of you ever have a project that has an unusual bolting issue,
    quallity S.H.C.S.'s are every bit up-to a mounting challenge
    as far as strenght etc. goes.
    Remember two things....
    1, If the application is in a harsh environment,
    Clean and fill the hex socket and the Counter'bore around each head
    with a high quallity R.T.V. or equiv.
    2, With socket head cap screws, (removal) you get one chance only.!!!
    If U use a rounded allen wrench of don't get it seated in the hex
    ALL THE WAY, you deserve the ensuing problem.
    vg
    Mar 2010
    SE Michigan
    2,049
    Vice Grip....
    I understand your point entirely and I prefer SHCS fasteners on machine tools, that's the industry norm, at least for quality machinery but on a truck, HCS is better from a removal/replacement standpoint with spline drive coming in second.
    Harris OA
    Jan 2011
    Stripped allen head
    If all else fails you can drill the heads off and slide your part off then take the studs that are left out with vise grips or pipe wrench. If the are 5\16 bolts use a 5\16 or 11\32 drill and drill in the center untill the head comes off.
    Mar 2006
    Willow Grove PA
    70
    one method we use alot, especially with TORX bolts on GM applications (they use them to bolt engine front accessories on that are gawd-awful tight), take a punch, and wail on that bolt head straight in with a big hammer(eye protection!). this impact slightly compresses the material being bolted together, as well as shocks the threads, and the bolts will usually get very loose and then are easily removed.
    we use this method on the TORX bolts because the TORX drivers are very weak, and we have snapped them off prior to using this method.
