Hey Peter,
To try to provide you some assistance in determining your outlay, you will have to formulate your approach for a repair.
1) Go price a new boat of the same mfg. or configuration.
2) After you have removed all the interior material, get out the yellow pages & start making calls to as many welding shops as there is in your area & see if they do aluminum and/or marine welding. Ask them if you could bring it by for an estimation. No one can give you an estimate without examining the entire gamut of repairs & possibilities of replacement of material.
3) Get WRITTEN estimates. Ask if the repair would be with MIG or TIG & not some Alumaweld with a propane torch. With each estimate, ask the owner/manager to see samples of their aluminum welding & the process used. If they start to squirm, you now have an indication that they would not be acceptable because you have some knowledge of the processes used & they would feel you would/could spot defects or sloppiness on their part. Any reputable repair shop would have no reservation to show you their work & quality & PROVIDE REFERENCES!
4) Most reputable shops would give you a call if they found anything additional that needed repair & the cost of repair is not in the original estimate. You would then have the opportunity to agree or decide you didn't want any more expense. DO NOT!! accept any additional costs if you did not PRE-APPROVE of the additional work. I've seen many really get burned with this tactic.
5) Be smart. THINK! Make sure you are aware of ALL circumstances prior to leaving your boat for a repair. Shop around..... I'm sure there is someone who is quite qualified to do the work, reputable, & hopefully, for your benefit, may be a bit slow with the economic situation & give you a real good deal just to get some work. You also have to understand that there will be NO GUARANTEE...... The repair shop has no idea of the usage of the boat once it leaves their premises. I hope you understand that. If you have any doubts at all, ask the repair shop to fill the boat with water while you are there & lay under it to SEE if it leaks. Remember.... "the proof of the pudding is in the eating." $500.......$5000, Yup.....somewhere in between.
Do your homework, Peter.
Denny
Complete weld/mach./fab shop
Mobile unit
