Results 1 to 12 of 12
    Tennessee
    1,166
    Stainless Steel with helium shield gas.
    I have a special assignment coming up and the requirement calls for helium instead of argon for my shielding gas. Now I've used helium for many years to DCEN aluminum and even been lazy enough to not change over bottles to weld some steel with the helium but this new task is something out of the ordinary. I've never seen a welding requirement for helium on stainless. This is at the NASA and you'd hope that they would know what they needed. The engineer claims that argon would introduce a contamination to the system. Must be a helium system I'll be welding on.
    Two turn tables and a microphone.
    S.E. Wisconsin
    4,472
    Oddly I have just been wondering about trying just that.
    I use 420 SS filler to build-up broken bolts.
    And on tooling of unknown alloy and/or hardness.
    I can't allways preheat an entire component.
    Focussing an argon arc to heat a region, is a tad too
    pointed, Maybe the nice wide hot cone from Helium
    would help. But then would it be a good weld?
    Or just a brain-fart.
    vg
    Aug 2010
    Laveen, AZ
    64
    Didn't the term heliarc come from that - helium arc? I think I read somewhere that Airco started it and their welder was called the Heliarc.
    The funny thing about a lot of engineers is their ego. They are like doctors and didn't learn how to say "I don't know," in school. However, they are part of the spoke in the wheel. Maybe this guy doesn't have your expertise and knowledge of welding processes and his ego won't let him admit it. Maybe you could coach him a little, not sure of your situation though.
    Little John Deere
    Hobart HH140
    Miller Thunderbolt 300 Arc Welder
    Victor Oxy/Acet. Setup from Grandpa
    Yeah, I have some Harbor Freight Stuff
    SR 71 Blackbird, picked up off of CraigsList
    Are you a proud American? Where are our leaders? Why did the easy questions become hard and the hard questions get answered without answers?
    5,332
    Check out the entries for the 1920's and the 1940's here: http://www.weldinginfocenter.com/history/his_01.html
    Gas tungsten arc welding (GTAW) had its beginnings from an idea by C.L. Coffin to weld in a nonoxidizing gas atmosphere, which he patented in 1890. The concept was further refined in the late 1920s by H.M.Hobart, who used helium for shielding, and P.K. Devers, who used argon. This process was ideal for welding magnesium and also for welding stainless and aluminum. It was perfected in 1941, patented by Meredith, and named HeliarcŪ welding. It was later licensed to Linde Air Products, where the water-cooled torch was developed.
    Here's a Heliarc setup from 1942 from an old Pop Science magazine:
    Dec 2005
    322
    As this thread has morphed in to a walk down memory lane... Here is a video of how welding was done in 1942 http://www.archive.org/details/WeldingO1942
    Ken
    5,332
    Oh, sorry, that was a recent pic of Vicegrip. I don't know where the old pic went.
    May 2009
    Gulfport, Florida
    1,960
    Pops, I bet you could not keep a straight face while you were typing.
    Sep 2010
    starkville, ny
    44
    Quote Originally Posted by urch55 View Post
    To be serious, even though that was funny. And was probably a pic of someone I know and welded with
    Helium is tough to weld with due to it much lighter than air, and to use it for a shielding gas for anything but overhead means you need to run way MORE gas than argon to get a good shield.
    The reason why it was heliarc to start with was helium was easier to bottle and get pure.
    I think chemistry bears out again.
    Sincerely,
    Kent
    5,332
    Pangea,
    Could the Helium requirement be a matter of the available purity of the gas?
    Tennessee
    1,166
    Pangea,
    No it seems that the gas issue has to do with the system being welded on. Either it has sensors vulnerable to Argon or the apparatus can't have any argon introduced into it.
    May 2007
    88
    Here is a tidbit I found in one of my books, regarding helium shielding gas with GTAW on SS. I've never personally used straight helium with stainless, so I can't personally make any comparisons.
    "For equal arc lengths and welding currents, the tungsten arc voltage in helium will be about 50% higher than the tungsten arc voltage in argon. While this permits more uniform joint penetration and higher welding speed, it also limits the use of this combination to thick sections (14ga-.074" or thicker)."
    Mar 2011
    155
    Helium gas usually increases penetration on thick sections.
    What is the welding process being used?
